Strange 07 WRX issue
Old May 2, 2010 | 09:30 PM
sidetrak's Avatar
Car Info: 2007 WRX Wagon
Hey guys, I've encountered an interesting issue with my car lately. (within the last 3 days) I purchased it 2 months ago (used) from the dealership, and had it evaluated at LIC. The car is fine, and other than the K&N intake that was on it when I picked it up, the engine is stock.
Let me preface to say that I'm planning to replace the intake with an OEM air-box regardless if it's the issue or not.
Basically I noticed this problem the other day while heading back North on 101 towards the GG bridge. It was pretty bad traffic and everything was at a slow crawl/ stop n go. At the point of incline, while keeping it in 1st gear, the car would start rumbling and struggle to pull cleanly up hill. After about 50 meters of trying to keep the car from dieing I started to smell the clutch burning.
My first thought was that the clutch was slipping and could be going bad. After reading around, it seems to me that the clutch isn't the problem. (it doesn't display the typical slipping clutch symptoms)
Is this just turbo lag, or is it an early sign of the engine running lean? I'm scrambling to figure this out before it's too late.
Any suggestions?
Old May 3, 2010 | 01:11 AM
Dnayukns's Avatar
Car Info: 07 Wrx
It wouldnt be in turbo lag unless ur in boost, most definitely not at a slow/stopped position.
You shouldn't be able to feel a lean/rich difference from just a intake, maby from a downpipe.
It might still be the clutch or tranny go get it checked out
Old May 3, 2010 | 03:05 PM
sidetrak's Avatar
Ok well, I've already started the process to have it checked out.
I'll post up the results after I get it back..
Thanks for the input!
Old May 3, 2010 | 04:47 PM
Dnayukns's Avatar
Car Info: 07 Wrx
Ur welcome! =D
Bump for more input
Old May 3, 2010 | 04:54 PM
04caliwrx's Avatar
just take it tp Subaru it is a 07 so you are still under warenty
Old Oct 6, 2010 | 10:49 AM
trubluevoeater's Avatar
Car Info: 2005 suby sti
sounds like clutch to me. did you hear back from them yet? could be sensor though. no engine light came on!
kyoung05
Jan 31, 2010 11:40 AM
stealthrex68
16
May 15, 2009 08:28 AM
stealthrex68
Aug 9, 2008 10:17 AM
Weak Sauce
Feb 21, 2005 03:44 AM
wrxlover
Sep 7, 2004 10:55 PM
