starting mods?
Old Jan 17, 2007 | 03:37 AM
kisono55's Avatar
Car Info: 06 wrx wagon
starting mods?
still new to the subaru scene. i have an 06 wrx wagon. need some suggestions on starting mods for my car.
was looking to slap on helix up/down pipe, hks hiper exhaust, hopefully an apexi avcr with a fc power commander, and a cobb accessport stage 1.
if anyone could give me some suggestions, id appreciate it. thanks!
Old Jan 17, 2007 | 07:01 AM
meilers's Avatar
stock answer: train the driver (better than current ability)
Old Jan 17, 2007 | 09:19 PM
06grayrex's Avatar
Car Info: 06 WRX TR Cobb stage 1, Perrin crank pulley, SPT intake w/shield, grounding mod, fog light mod
+1 on training the driver..
It really depends on how much money you want to spend. A good start would be EM like cobb for example. If you have more resources then next whould be a dp and exhaust. Now if you do not want to spend a lot of money then a light weight crank pulley, intake (SPT, K&N, Cobb) can help make the car more responsive for a few bones. I would really start with some sort of EM if you can then build from there. Have fun
Old Jan 18, 2007 | 12:53 AM
kisono55's Avatar
yups thanks. i've actually had the car for about a year. but yah still getting use to it, love the feeling. i was looking into getting the cobb AP and downpipe and exhaust together. then proll intake, up pipe and boost controller. thanks for the advice!
Old Jan 18, 2007 | 01:04 AM
06grayrex's Avatar
Just so you know..Don't worry about the up pipe because it has no cattalytic converter.....The AP from is all you will as far as a boost controller. If you need more boost than what the AP can provide then you should probably have your car pro-tuned.
Old Jan 18, 2007 | 09:21 AM
PghRedBean's Avatar
Car Info: I ride
Just an FYI...if you go with DP and exhaust, you will need to run the AP Stage 2 map. Stage 1 is not programmed to compensate for the Downpipe. You would probably end up seeing boost spikes and possibly damage your motor.
TheOnlyLotus33
Jun 26, 2007 09:27 PM
seri_808
Jun 27, 2006 12:05 PM
MaxBoost
Jul 29, 2003 12:02 AM
MeddlingKids
Jan 30, 2003 12:55 PM
wrxnate
Dec 19, 2002 06:40 AM
