SOHC heads on EJ257 STI block.
Old Jul 26, 2005 | 06:46 AM
GrandpreRS's Avatar
Will mating EJ253 SOHC heads in an EJ257 STI block lower the compression? If I put STI rods and pistons in the stock ej253 would that lower the compression?
Old Aug 1, 2005 | 01:35 AM
GrandpreRS's Avatar
If i turbo EJ257 sti block with SOHC heads will i need the sti ecu?
Old Aug 1, 2005 | 01:48 AM
GrandpreRS's Avatar
or can I run my stock EJ253 ECU with the turbo sti block?
Old Aug 22, 2005 | 04:31 PM
chinoWRXL's Avatar
bump
interested to know myself
Old Sep 2, 2005 | 09:57 PM
fastnoypi's Avatar
just a wild guess you dont need an sti ecu because you wont be running avcs.
call up crawford performance or axis, im sure they have experience with the differnent head selections on a ej257
Old Sep 11, 2005 | 12:04 AM
Krinkov's Avatar
wow this would be a project! though the SOHC heads would most likely raise the compression WAY to hell. I honestly dont think this is a very practical project though, you might as well look out for a set of WRX heads, they are not that expensive nowadays
dlgonsalves
Jun 23, 2010 12:37 PM
Pi7467mp
40
Sep 5, 2005 09:16 PM
Pi7467mp
Jan 6, 2004 07:40 AM
Pi7467mp
Nov 20, 2003 06:44 PM
scoobydoo
May 6, 2003 06:37 PM
