Snorkus Delete 06 sti directions
Old Oct 9, 2006 | 03:33 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
Exclamation Snorkus Delete 06 sti directions
questions:
if i do this then what parts will need to be replaced? or do i just need to connect or get rid of some parts?
Old Oct 9, 2006 | 04:34 PM
SUBY_6_STI's Avatar
Car Info: 2006 STI CGM
You will need this...
http://www.fastwrx.com/insnre.html
and this...
http://www.scoobymods.com/forums/showthread.php?t=113
:edit: This topic is all over the boards...Search and you will find.
Old Oct 9, 2006 | 04:43 PM
NW OBS's Avatar
Wink
You delete the 'snorkus'. At this point you can pitch the intake scoop (that pulls air from the front of the car) and just add a straight 3" (or curved) ABS pipe in the hole @ the airbox (which will pull cold air from the fender. OR, keep the intake scoop and buy a GP Moto 'U' that will connect the scoop back to the airbox.
*** I have run both ways and felt no difference with one over the other. So, I have chosen to pitch the large plastic scoop and go with a pipe right out of the air box into the inner fender. ***
Old Oct 11, 2006 | 10:39 AM
moffman42's Avatar
Car Info: 2006 WRX STI
where did you get the abs pipe?
Old Oct 11, 2006 | 11:26 AM
NW OBS's Avatar
Ace hardware. I think was about 6" long and I cut 3" off it, so it just pokes into the inner fender. It is fairly safe from water intrusion being that high in the fender (I live in Oregon) and our boxes are designed to hold any water under the filter as a secondary safe-guard.
damianwrb07
Feb 1, 2012 12:51 AM
pope 06 2.5i
14
Apr 26, 2007 04:27 PM
flipmode
Dec 15, 2005 07:46 AM
PurduePhiGam
Aug 1, 2005 11:30 AM
hezlok
Feb 15, 2005 11:37 AM
