Smog problems need help!
Old Jan 15, 2013 | 07:51 PM
AWDSYCO's Avatar
Car Info: 00 RS
E85 will destroy your seals. I play tennis at Monterey tennis center every weekend near Jack's Park if you can wait to the weekend. Most likely your O2 rear sensor is not working correctly. This SW can plot real time how O2 sensor behaves. Pm me your cell.
Old Jan 15, 2013 | 07:56 PM
cwc16's Avatar
Car Info: 17 WRX
hmm ill have to check that out. how easy is it to fix? unfortunately im going to be out of town this weekend.
Old Jan 15, 2013 | 08:05 PM
AWDSYCO's Avatar
Car Info: 00 RS
I agree that you need to drive at least 30 min in order for the cat to get hot enough to function correctly. Especially lately cold weather your car probably running OPEN LOOP with rich fuel caused your cat not to work properly, dumping a ton of HC to the pipe. The catalyst needs to be extremely hot to burn the excess HC, otherwise your car will fail.
Try this first, if failed I'll hook it up for you Wed/ Thurs
Old Jan 15, 2013 | 08:08 PM
cwc16's Avatar
Car Info: 17 WRX
hmm i may try to get some e85 and just get the car very warm like you all suggest and then try it again.
Old Jan 15, 2013 | 08:23 PM
AWDSYCO's Avatar
Car Info: 00 RS
Drive high speed on highway 1 for 30 min, ECU will switch to close loop mode and uses O2 sensors to control emission. You will pass smog tomorrow is my bet even without E85.
Old Jan 15, 2013 | 08:26 PM
cwc16's Avatar
Car Info: 17 WRX
you think its worth trying without the e85? if it saves me driving up to san jose i am definitely keen on trying it
Old Jan 15, 2013 | 08:38 PM
AWDSYCO's Avatar
Car Info: 00 RS
Don't need E85. You drove in city for 5-10 minutes is not enough to reach operating temp for emission purposes. That's why O2 sensor also have 4 wires where 2 of them is the heater to assist quicker warm up so your ECU reaches close loop more quickly, not dumping a ton of fuel to the pipe. When you get to smog station, keep it running to keep it hot.
The tech should not charge you, tell him your car was not fully warm up last time tested.
Old Jan 15, 2013 | 08:45 PM
cwc16's Avatar
Car Info: 17 WRX
most definitely thanks so much for the help man. I will try this tomorrow, and I will get back to this thread. wish me luck haha
Old Jan 15, 2013 | 11:19 PM
Heedz's Avatar
Nobody likes the tuna here
What seals are you talking about? My car's been running on 91 + E85 for the last I dunno 5 years?
Old Jan 16, 2013 | 04:59 PM
cwc16's Avatar
Car Info: 17 WRX
I passed without e85! Just drov nice and hard for about 30 min and here I am thanks guys!
Old Jan 16, 2013 | 06:27 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
nice!
Old Jan 16, 2013 | 08:11 PM
AWDSYCO's Avatar
Car Info: 00 RS
Great news, you should come by Monterey tennis center say hi sometimes. Did they retest for you free?
Old Jan 16, 2013 | 08:23 PM
cwc16's Avatar
Car Info: 17 WRX
the shop i tried yesterday was closed... so i had to pay another 40 but it is smogged! thanks so much! I will definitely come say hey! shoot me a text 8313200006 and ill come by maybe next weekend when im in town!
Old Feb 25, 2013 | 04:01 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
In the op I noticed you said you uninstalled your ap map. You may be running Ritch? Maybe put your map back on a try that
DabiDa
Aug 16, 2013 11:43 AM
wrx 03i
Aug 18, 2011 06:58 PM
freshrex
Mar 23, 2011 11:46 PM
AWDnutjob
32
Jul 6, 2008 06:06 PM
grex767
May 27, 2006 10:37 AM
