Question about turbo sputtering
Old Dec 9, 2013 | 09:43 PM
j0mz's Avatar
Car Info: Sti 2007
When I step on the gas and kinda smash my car and when my turbo spools it sounds like its sputtering. This is actually my first turbo car so I'm not quite sure what's going on. Mods turbo back. Spt intake. Turbo xs re circulating bov. Stage 2 Cobb map. It does not sound it's spooling smoothly.
Any opinion will be greatly appreciated.
Thanks guys.
Old Dec 9, 2013 | 10:09 PM
edzwrx's Avatar
Car Info: 2004 WRX Sport Wagon
Check the hoses on the turbo and the vacuum hoses if they popped out.
Old Dec 9, 2013 | 10:21 PM
j0mz's Avatar
Car Info: Sti 2007
Ok cool. Anything else should I look at?
Old Dec 9, 2013 | 10:32 PM
edzwrx's Avatar
If the hoses on the turbo and vacuum are ok, then check the turbo if there's cracks on the housing and bent fins on the compressor wheel.
Old Dec 9, 2013 | 10:43 PM
j0mz's Avatar
Car Info: Sti 2007
Oh damn hopefully its only loose hose or vacuum leak. Thanks man appreciate it.
Old Dec 9, 2013 | 11:01 PM
silverbullet415's Avatar
sounds like a boost leak...
Old Dec 9, 2013 | 11:07 PM
j0mz's Avatar
Car Info: Sti 2007
Gotcha. Ill check the clamps on the tmic.
Old Dec 12, 2013 | 05:48 AM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
FYI, you cannot use an SPT intake with the Cobb maps. Custom tune required.
Also, ditch that TXS valve. The TXS H-Line is well known for being crappy valves. They very often leak, and that could actually be your problem.
Old Dec 12, 2013 | 06:57 AM
j0mz's Avatar
Car Info: Sti 2007
Gotcha it came with the car and it did not have the oem box. Yeah I was actually thinking about taking the bov out.
Old Dec 15, 2013 | 08:23 PM
j0mz's Avatar
Car Info: Sti 2007
So update. I put the OE bov back on. Checked all the hoses and tighten all the clamps. The car runs better and picks up faster. But there still a little bit of sputtering at about maybe 5000 rpm. I'm planning to buy a cobb intake and replace my spt.
Old Jul 6, 2014 | 09:47 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
I had the same issue when I was on similar mods with a K&N typhoon. Once I went back to the stock intake the problem went away.
Old Feb 11, 2015 | 09:09 PM
cracker1252's Avatar
Car Info: 2008 Forester XT Sports
sorry, bringing this back alive. if you happen to see this....does it throw a code at all?
Papa Bear
Nov 8, 2010 08:50 PM
woocabin
May 12, 2010 06:45 PM
chinosubie05
Feb 19, 2008 10:37 PM
silentmark
Aug 18, 2007 09:37 AM
harley29906
Mar 12, 2007 05:14 AM
