numbers from FP GREEN upgrade
Old Jun 20, 2007 | 02:58 PM
whtSTI04's Avatar
Car Info: 04 STI
OK i have a 04' sti that recently BLEW up..... soooo i ordered a stock OEM 2.5 liter block which just came in.... iam going to have it built up a bit by GST motorsports in hayward. while i have the engine out iam having a FP green turbo instaklled at the same time. i was just curious what kind of numbers i will put out......
the block will consist of......
- 100 MIL overbore JE pistons with coated rings skirt and tops
- heads will be tested and milled
- main and rod bearings ACL coated
- kevlar timing belt
- APR headstruts
- some short block machine work will happen to.....
^ not a whole compleate build up, but guess thats the options they have given me so far......
as for turbo parts....
- FP green TD06 turbine( 3' intake inlet and 8cm housing)
-perrin 3' inlet hose
-perrin FMIC
-PE 850 CC injectors
-perrin fuel rails
-custom intake
-AP
^ annnd i will be running 100 octane
fourZero
Jul 5, 2009 08:11 AM
SubySal
Dec 3, 2003 08:22 PM
1Slow///M3
Sep 5, 2003 07:28 AM
aWrxer
Apr 23, 2003 10:37 PM
EvasionOfTruth
Dec 2, 2002 07:48 PM
