Just formed a problem :(
Old Apr 22, 2010 | 07:43 PM
04wrxGreg's Avatar
Car Info: 04 subaru wrx
I dont know what just happened. car was hitting target boost of 16-17 just fine, now when it hits 14psi, in any gear, the car stalls. wont hold above 14. did i just blow my td04??? or could it be something else??
Old Apr 22, 2010 | 07:52 PM
xhengmanx's Avatar
well if you have an sti.. you shouldn't have a td04 in it. maybe a bad boost control solenoid?
Old Apr 22, 2010 | 08:21 PM
soggynoodles's Avatar
well if you have an sti.. you should have a td04 in it. maybe a bad boost control solenoid?
You mean shouldn't
04 Sti's came with a vf39 turbo
Old Apr 22, 2010 | 08:31 PM
johndabrit's Avatar
Da Brit.
You mean shouldn't
are you tuned? if so, which boost controller?
Old Apr 22, 2010 | 08:37 PM
xhengmanx's Avatar
corrected!
Old Apr 23, 2010 | 12:32 PM
St0ich's Avatar
Car Info: 2005 WRB wagon / 2006 Red Toyota Tacoma
Unplug the battery and reset. this sometimes works... GL
Old Apr 23, 2010 | 04:54 PM
nation's Avatar
Car Info: 2006 sti
im going to say theres a tear in a hose.you build boost,tear opens up and problems start.check ALL vaccum lines and couplers for holes/tears.
Old Apr 25, 2010 | 11:15 PM
04wrxGreg's Avatar
well, after a trip out of town with the tank of gas that i filled up locally (when the problem started) and having to refill out of town, the car seems to be running 17psi again in every gear without any hesitation. seems i've picked up some bad gas at my local chevron. (and yes.. i DID put 91 oct. in it) thanks for your guy's time and help
Jaister
Sep 30, 2011 01:38 PM
black25rs
Mar 21, 2004 01:07 AM
yodler
Mar 5, 2004 11:06 AM
PhillyWRX2
Apr 21, 2003 07:17 AM
