how often should OEM air filter element be replaced?
Old Jun 5, 2006 | 09:58 PM
equinn2823's Avatar
Car Info: 2006 wrx limited sedan
how often should the oem filter be changed?
Old Jun 5, 2006 | 11:56 PM
Wingless Wonder's Avatar
Origami posted by equinn2823
30 months or 30,000 miles, whichever comes first. Sooner if vehicle is operated in very dusty areas. Here is the maintenance schedule that is also included with the packet of materials that accompanies your Owner's Manual. Check your packet since it may have updated information on your model year. Here is a how-to on replacement of the air filter element.
Your original post was split off from another thread and will eventually be moved to the Maintenance & Warranty Forum.
Old Jun 6, 2006 | 12:04 AM
VRT MBasile's Avatar
hmm...maybe I should check mine. 2 rally-x's, a few spirited dirt road runs, and living in the boonies...
Old Jun 6, 2006 | 12:14 AM
thevanitygroup's Avatar
Car Info: 2005 Subaru Impreza WRX STI
^sounds like a wise idea. although dont be to worried, out of all the things on your car that you let go longer on the maintenance schedule, the air filter is the least likely to cause any problems. it just filters better when dirty and flows a little lower. your filter is rated above your cars WHP rating so your fine. it is best however to always follow your SOA recommended service periods.
c0mrade
Jul 24, 2006 12:03 PM
Wingless Wonder
Jun 7, 2006 11:48 PM
WindingRoad
Oct 29, 2004 01:01 PM
jasno999
Jan 22, 2004 08:58 PM
GM6
Sep 29, 2003 11:42 AM
