Accessport live boost reading.?
Old May 27, 2006 | 01:12 AM
lburrrna's Avatar
Question Accessport live boost reading.?
How do i read live boost? once i hook it up, i go to live boost..then i gives me blank! i heard somebody said that i press the gas pedal so in that case the car has to be running? can somebody confirm this? i need HELP.
Old May 27, 2006 | 07:56 AM
wu!'s Avatar
wu!
Car Info: '18 WRX Premium, '14 320i xDrive
Confirmed. Your car has to be running. At idle, you'll get negative readings. After you step on the throttle, the readings will go from negative, to zero, to positive.
I don't remember what the max boost reading is on my '06 WRX because it's hard to drive WOT and look at the AP at the same time.
Old May 27, 2006 | 06:41 PM
lburrrna's Avatar
oh thanks, i hook it up first then start the car? or the other way around?
Old May 27, 2006 | 06:49 PM
wu!'s Avatar
wu!
The order won't matter. Just today, I got a reading of around -10.1 or -10.2 at idle. I got a peak reading of high 14s, then it tapered around 12.
I have an '06 WRX as well on the Stage 1 CA map.
Old Jun 2, 2006 | 11:33 PM
lburrrna's Avatar
im think im not getting the target boost, i have somebody to hold my ap and ill drive and see wats the result. im aso getting -10.1 to -10.2 during idle, in idle if i press the gas and rev to close to red line i get around -9? is that normal, or i just need to drive it in WOT?
Old Jun 3, 2006 | 02:17 AM
Boost Addict's Avatar
I imagine youre referring to free-revving the car... I don't think youd be buildng much boost, given that the engine is not under load, you need to do this while driving... or at least thats my guess.. besides free-revving is not healthy for the engine.... especially to redline man...
Old Jun 6, 2006 | 10:03 AM
okpanic's Avatar
Car Info: 07 Silver Mazdaspeed 3
Okay....... Firrst off you will need to be driving. The freeway is the best place for WOT tests. Plug the AP into the car and just cruise and you'll see the reading go up and down depending on the throttle position. Then drop a gear and floor it and you should jump up fast and then tapper off. My sti hits about 17.5 before it starts coming down.
lburrrna
Jun 2, 2006 10:31 AM
K I T T
Apr 8, 2005 12:59 AM
spdkills
May 13, 2003 03:54 PM
huffyrex
Apr 17, 2003 10:11 AM
RogersWRX
Rocky Mountains
Feb 20, 2003 09:24 PM
