how often should the oem filter be changed?
[quote][size=1][color=gray][i]Origami posted by [b]equinn2823[/b][/i][/color]
[font=Arial][color=royalblue]how often should the oem filter be changed? [/color][/font][/size][/quote]30 months or 30,000 miles, whichever comes first. Sooner if vehicle is operated in very dusty areas. Here is the [url=http://www.cars101.com/subaru/subaru_maintenance.html][color=deeppink][b]maintenance schedule[/b][/color][/url] that is also included with the packet of materials that accompanies your Owner's Manual. Check your packet since it may have updated information on your model year. Here is a how-to on [url=https://www.i-club.com/forums/showthread.php?t=135566][color=deeppink][b]replacement[/b][/color][/url] of the air filter element. Your original post was split off from another thread and will eventually be moved to the Maintenance & Warranty Forum. [size=1][color=skyblue]-- 0==[color=blue]WW[/color]==0 "…axles of evil…" - george w. bush[/color][/size] |
hmm...maybe I should check mine. 2 rally-x's, a few spirited dirt road runs, and living in the boonies...:D
^sounds like a wise idea. although dont be to worried, out of all the things on your car that you let go longer on the maintenance schedule, the air filter is the least likely to cause any problems. it just filters better when dirty and flows a little lower. your filter is rated above your cars WHP rating so your fine. it is best however to always follow your SOA recommended service periods.
