hks fcd?
Old Dec 21, 2006 | 04:10 PM
07blacktr's Avatar
Car Info: 07 WRX TR
hks fcd?
hey im new to the forums and to subaru i have a 07 wrx tr with tbe,injen short ram and a walbro 255 fuel pump and in 3rd gear and on it is hitting fuel cut so i bought a hks fcd and wanted to know wat to set it to cause first and second it is hiting 14 psi and right before it cuts out its at 16psi....what should i set the fcd too?
Old Dec 21, 2006 | 05:00 PM
Superglue WRX's Avatar
You should set it to the trash and get an actual tune. The fuel cut is there for a reason.
Why do you have a fuel pump? I'd also like to know how you managed to get 16pis in 1st and 2nd gear.
Old Dec 22, 2006 | 09:48 AM
07blacktr's Avatar
Car Info: 07 WRX TR
1st and second are hitting 14 3rd and on are hitting 16+
Old Dec 22, 2006 | 09:56 AM
Egan's Avatar
You should get some form of engine management. I run over 18PSI and have never had a fuel cut issue. The HKS Fuel Cut Defender only bypasses your car's built-in safeguards, it does not solve the problem. A proper tune will maintain the proper safeguards and allow for higher boost and take into account all of your other modifications, maximizing their potential.
AllWheelMotion
Dec 5, 2003 08:23 PM
ridebmxsvt
Oct 23, 2003 11:43 AM
besta007
Apr 8, 2003 01:38 AM
View Askew
Apr 8, 2003 01:36 AM
Ditty77
Feb 22, 2003 11:39 AM
