Hesitation Issue Uphill???
Old Mar 9, 2010 | 09:44 PM
bpatrick's Avatar
Car Info: 2007 Impreza WRX Limited Bugeye Conversion
I have been noticing some weird hesitation issues about 0-5 psi boost going uphill at freeway speeds. The motor feels like its bogging down and then when I hit the gas, spools up normally. Anybody else experience this or have idea what might be causing it?
2007 WRX Stock turbo 53k
Current engine mods: Custom Tune by Ed at EQ Tuning, Crucial dp and race pipe, HKS Carbon Ti, K&N Panel filter, oil catch cans.
Old Mar 11, 2010 | 03:08 PM
bpatrick's Avatar
I just cleaned the air filter and it seems to have gotten a little better... Any other ideas? I don't want to run lean and fry the motor
Old Mar 11, 2010 | 03:37 PM
azer408's Avatar
Car Info: 2006 CGM Impreza WRX/ 1998 RBP Impreza 2.5RS
Can you pull up any possible live data?
Old Mar 11, 2010 | 09:13 PM
bpatrick's Avatar
I am planning on doing that this weekend... Hopefully I'm not running too lean
Old Mar 14, 2010 | 11:07 PM
NorCalSubie07's Avatar
Car Info: 07 STi Limited #359 UGM
hey, I use to have the same problem when i had my wrx. Are you experinceing worse mpg? Mine was the weirdest thing and got worse over time. It would start to bog down then stutter then hit boost hard and start going fine. Started doing it when it was stock and then then I put on similar mods as you and then had it tuned at eq thinking a tune would rid the problem. Once tuned the car didn't do it for a couple months and then it came back and started acting very weird again. I did a years worth of problem solving and then had a subaru specialist pull logs from the car and what not and it seemed to be problem with the ecu that was a manufactures defect or something. All in all the car was just a huge problem. Cut my losses, sold the car when it was acting ok and bought a 07 sti limited . I wish you the best with your car, eds a great guy and im sure will help you out with your problem. Hope to hear what your answer to the problem is/was.
Old Mar 15, 2010 | 04:39 PM
bpatrick's Avatar
I changed the air filter and seems to have gotten better. I logged a few pulls this weekend, but I haven't had time to load the data and analyze it. Just by looking at the Cobb while driving, the AFR looked stable with a low of 11.0 (wot), a high of 20.4 (no throttle) and cruising about 14.6, EGT's on the downpipe at 1200 max and no boost creep. Sooo.... we'll see
Old Mar 15, 2010 | 04:42 PM
bpatrick's Avatar
mpg is about the same. I hope that it's not my ecu, I'd hate to have been crapping out my motor all this time. Ed is definitely a great guy to work with and if I can find anything myself, I'll be contacting him again. Thanks bro, jealous of the limited but what a sucky way to get it.
Old Mar 18, 2010 | 04:31 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Hey Bobby... let me know if you can't figure it out. Also, if you can log the issue with the AP, e-mail me the logs and I'll be happy to look them over.
-- Ed
Old Mar 18, 2010 | 08:40 PM
bpatrick's Avatar
Full pull 1st, 2nd, 3rd gear...
So what do you guys think?
Old Mar 18, 2010 | 08:48 PM
bpatrick's Avatar
Tried to recreate the scenario...
About 70-75 mph uphill
hotflare
Nov 20, 2013 11:41 AM
Drimmie
Aug 4, 2006 11:22 AM
stevedood
Sep 9, 2004 07:01 AM
yerrow
Jul 16, 2004 04:01 PM
Rallysportz
Sep 24, 2003 07:51 AM
Top
