Help! "Ticking" noise
Old Feb 10, 2004 | 07:40 PM
dartheadz's Avatar
Car Info: 2004 WRX STi
i had my car (04 STi) up on a lift last night to install a cat-back.....the install went great and appeared flawless. BUT....now i seem to have a ticking noise when slowing down, almost as if i were running over ice cubes....in the four corners of my car....its not coming from underneath, like where the new exhaust is....so i remain confident in my mechanical skills....but is it possable that raising the car up on the lift did something to my differential, or the AWD? does this happen? sorry if my description of the problem is unclear....
Old Feb 10, 2004 | 07:49 PM
Daredevil's Avatar
you have a new catback on, you'll be hearing new noises, i woudln't worry about it
puttin it on a lift won't hurt your suspension unless you do it horribly wrong somehow, in some way i can't think of
Old Feb 10, 2004 | 09:04 PM
dartheadz's Avatar
they will eventually go away? im not cut out for this, see: too paranoid.
Old Feb 10, 2004 | 09:52 PM
Daredevil's Avatar
*shrug* prolly not, its jsut a noise that is more noticable now that you have a catback
everytime you do something to your car you will notice something different
hell, when i got out drivin real hard, i always freak otu and think its not drivin the same, something has to be wrong, 2 days later im like, bah all in my head
Old Feb 10, 2004 | 10:44 PM
Wutzdatbehindu's Avatar
Car Info: 2002 Subaru WRX
Just out of curiousity, what points did you use to lift ur car?
Old Feb 10, 2004 | 11:56 PM
Wingless Wonder's Avatar
Look underneath your car while you try to move the muffler tip from one side to the other. If it has a lot of movement, see if it makes contact with anything under the car. The most common point of contact is a structural crossmember for the suspension. Often stiffer urethane exhaust hangers like Kartboy's will limit movement enough to eliminate or at least reduce the contact.
Old Feb 12, 2004 | 07:06 PM
ImpSP's Avatar
Car Info: 1997 impreza L
When my car slows down, my exhaust pipes rattle against my heat shields. Don't know if that sounds like ice cubes but it might.
Old Feb 16, 2004 | 01:28 AM
iNfEk's Avatar
it could be your heat sheild or it could be your exhaust piping slightly banging against your rear diff get some kartboy hangers and it should minmize or get rid of this problem.
Old Feb 17, 2004 | 05:40 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
i agree- - - i know so many sti(newbie) owners that freak when they hear noises- you put somethin new on your car- it will affect it(audibly) have confidence in your install(or just retrack your efforts) then panic if you remeber doing or NOT doing something right. sti's or noisy to begin with so hopefully you get used to hearing odd noises. just tryin to help dude
EK
Dec 2, 2014 02:23 PM
EK
Dec 2, 2014 02:21 PM
turbo_j
Jun 13, 2003 11:26 PM
hilife
Mar 16, 2003 08:34 AM
AFIwrx
Feb 26, 2003 11:18 PM
