DCCD/ Gas mileage
Old Jul 24, 2004 | 11:45 PM
  #47
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
Originally Posted by gertman
Also, it is FINE to adjust the DCCD while moving. I just wouldn't suggest going all the way to locked while in motion unless you are on a surface other than DRY pavement. ex ICE, SNOW, GRAVEL
very true-
i sell em and i have one - i suggest to NOT set-up to 50-50 on pavement unless its very slick... i have mine in auto and i have been getting 17-19 mpg with 92 octane.(driving moderately hard)
on a side note the auto is primarily set on 35/65 and only adjusts to other settings if needed. i don't really care for the 35/65 to be set manually- sometimes i like the "clawing" effect of all that 300 lbs. ft of torque hitting that pavement!
ironically subaru has not yet released a chart describing all the settings inbetween. i know that lock is 50/50 and the green at the bottom is 35/65. but i'd like to know just exactly what everything elase inbtween is.
getting back to subject- you are actually getting decent mileage if you are driving normal- those numbers posted on your manufacturers sticker when you bought the car are if anything- magical numbers. my only suggestion is this- adjust your shift patterns. -->picture (scroll down)
Old Jul 25, 2004 | 10:44 AM
  #48
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Gregg's drawing makes my eyes bleed. So are you suggesting going from 1st to 3rd to 5th?
Old Aug 1, 2004 | 08:39 PM
  #50
EMOE3's Avatar
Idiots at CARB
Originally Posted by stott
I have also noticed that whatever it is that is unique to the special California Reformulated gas to make it cleaner just destroys Mileage. I tested this on about 6 cars shipped out from the east coast. All of them got about 50% more out of a tank than on the crappy Ca. gas. I find it hard to believe that using that much more gasoline makes the air cleaner, but I am sure studies were done.
http://www.stifiles.com
I've read that worse gas mileage w/ oxygenated gas in EFI cars is true. The extra O2 in the gas makes the car run lean which is corrected by the comptuer by adding more gas! Supposedly they did this in CA to make older carburated cars runner cleaner, but as a consequence cause the majority of the cars to use more fuel...
Old Aug 20, 2004 | 11:03 PM
  #51
gdogg's Avatar
if u look at my pic.. there is a smiley... i was kinda joking....
tbonetristy
Sep 7, 2006 02:06 PM
wu!
May 23, 2006 04:28 PM
Milruner
Apr 12, 2006 05:06 PM
Icon25rs
Feb 19, 2005 08:12 PM
kidatari
Sep 9, 2004 12:22 AM
