check engine and flashing cruise light
Old Mar 15, 2007 | 02:14 PM
got boost's Avatar
Car Info: 06 WRX
alright i'll do that....thanks for your help guys
Old Mar 16, 2007 | 01:09 AM
medicSTi's Avatar
Car Info: 2018 STi
if you still want an intake go for the cobb short ram, its made of a plastic similar to your stock one that is supposed to handle the heat dissapation issues better than other aftermarket systems which heat up and make you run lean. mike at gstmotorsports sells them along with a bunch of other vendors. its only $150.
Old Mar 16, 2007 | 10:46 AM
Eckshero's Avatar
Car Info: 06 GDB dirty white
yeah i had the same problem when i had my injen CAI first on. i would have gone with cobb but my cousin works for injen and paying $100 for a regularly $350 CAI. i couldnt pass it up. but yeah just reset ur ECU.
Old Mar 16, 2007 | 12:11 PM
pwn's Avatar
pwn
Car Info: 09 STi, 10 Cayman S
I think people that do that are so fricken stupid. No offense but come on, 50$ more for something thats not gona hurt your engine, or save 50 bucks and run lean and down the road potentially run into a problem? Im not saying that the amount of leaning that the cai is causing will necesarily do damage, but lean is what leads to a blown engine.
Old Mar 16, 2007 | 06:35 PM
Eckshero's Avatar
ok but with my tune whats the diff?
Old Mar 16, 2007 | 07:19 PM
pwn's Avatar
pwn
Did you get tuned for it?
Old Mar 17, 2007 | 10:25 PM
Eckshero's Avatar
well durr
Old Mar 18, 2007 | 09:54 AM
Deadbolt's Avatar
Car Info: 2004 STi
Originally Posted by impreza-tux-121
haha. Yeha that happen to me too. If you get a SPT Intake like I did your cruise wont blink and check wont come on.
WHO NEEDS SPT HEAT SHIELD WHEN U HAVE AN INTERCOOLER?!!
Well this just happened to me today. I had the cc set and the CEL cam on and the cc stopped working. Now I have a blinking cc light and a CEL light. What is the right way to correct this?
By the way I have a SPT intake and heat shield.
Old Mar 18, 2007 | 03:55 PM
tanz1983's Avatar
Car Info: 2006 San Remo Red WRX
even the SPT intake has flaws. The best one is the Cobb one because it is pastic and doesn't retain heat. The best way to fix this is put your stock intake back on. To get rid of the cel, unplug your battery and press the brake 20 times. then reconnect your battery and it should be fine. If you have an accessport, reset the ecu
Old Mar 18, 2007 | 04:06 PM
Deadbolt's Avatar
Car Info: 2004 STi
I did exactly that earlier today. Disconnected the battery for about an hour and solved the CEL.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
splitsecond
Jul 31, 2005 02:39 AM
Kevex
Feb 6, 2003 07:35 PM
