check engine and flashing cruise light
Old Mar 10, 2007 | 12:00 PM
got boost's Avatar
Car Info: 06 WRX
about a month ago i put on an APS cold air intake and i got a check engine light and a flashing cruise light so i took off the map sensor plugged it back in and it no longer came up....now yesterday i went on a trip about 80 miles and then back and then i stopped to get a drink and left the car running and when i get back out i got the check engine and flashing cruise light again....and I tried doing the same thing with the sensor but it still comes up...can anyone help me out with what they think is wrong?
Old Mar 10, 2007 | 09:57 PM
tanz1983's Avatar
Car Info: 2006 San Remo Red WRX
take off the CAI. the heat that it retains throws off the reading of the sensor causing you to run lean.
Old Mar 10, 2007 | 10:30 PM
got boost's Avatar
Car Info: 06 WRX
will i have this problem if i get a short ram? like cobb or aps one?
Old Mar 10, 2007 | 11:54 PM
06d's Avatar
06d
Car Info: 2006 aspen white wrx
did u try disconnecting the battery n connect it n press the breaks 20 times
Old Mar 11, 2007 | 09:21 PM
got boost's Avatar
Car Info: 06 WRX
no i didnt....wouldn't disconnecting the battery mess with my accesport?
Old Mar 12, 2007 | 06:53 AM
tanz1983's Avatar
no, the map will stay on your ecu. any type of metalic intakes will retain heat. your sensor bolts to the metal of the intake. the sensor gets hot. this causes the car to cut fuel thinking the air is hotter than it really is.
Old Mar 12, 2007 | 07:39 AM
VRT Gump's Avatar
Cai Ftl!!!
Old Mar 12, 2007 | 06:28 PM
got boost's Avatar
Car Info: 06 WRX
cai ftl???
Old Mar 12, 2007 | 06:54 PM
1sicwrx's Avatar
Originally Posted by got boost
cai ftl???
CAI FTL= cold air intake for the loss as opposed to FTW(for the win). The Cobb short ram is one of the few that is compatable with your MAF unlike all the others.
Old Mar 12, 2007 | 10:36 PM
got boost's Avatar
Car Info: 06 WRX
i dont think that the heat as anything to do with it...i can start it up cold in the morning and its on....
--yeah i was thinking about just gettin the cobb short ram and hope that does the trick
Old Mar 12, 2007 | 10:51 PM
VRT MBasile's Avatar
you shouldt have a CAI, and you shouldnt have an intake with the AP unless youre protuned
stock airbox FTW unless youre pushing something like 400+HP
Old Mar 13, 2007 | 08:26 AM
UK n00b's Avatar
Car Info: the blue bucket
Seeing as you have a AP can you read the code and tell us what it is?
Mike
Old Mar 13, 2007 | 07:44 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
Exclamation
haha. Yeha that happen to me too. If you get a SPT Intake like I did your cruise wont blink and check wont come on.
WHO NEEDS SPT HEAT SHIELD WHEN U HAVE AN INTERCOOLER?!!
Old Mar 14, 2007 | 10:29 PM
got boost's Avatar
Car Info: 06 WRX
i checked the CEL code its"P0171"....anyone know what that is?
Old Mar 15, 2007 | 06:06 AM
tanz1983's Avatar
P 1071 means that you r system is too lean. It is the intake. Trust us on this one. Take it off and reset tyour ecu with the stock intake on the car. the light will go away and your car will be fine
