Boost Cut
Old Aug 13, 2008 | 06:01 PM
jazzml's Avatar
Car Info: 2007 sti in shop...itll be a suprise...
Question Boost Cut
When im driving and i look at the stck boost gauge sometimes it will go up to .05 and then it will only go to .10. Do you guys know what the problem could be. It happens on and off. Like sometimes its fine itll boost all the way and at other times it just dosent boost right. The only mods i have a are a muffer delete.
Old Aug 13, 2008 | 07:41 PM
BenBuser's Avatar
Car Info: 2002 Wrx Wagon Vf34 EQ tuned
try disconnecting the connector on the negative battery terminal next time it happens then push the brake a few times. then reconnect the cable. this may fix the problem but i have found it is only a matter of time until it happens again. my car has been acting up like this too and im going to take it to a shop soon to try to figure out whats wrong or what sensor is bad.
Old Aug 14, 2008 | 09:33 AM
OneManArmy's Avatar
General Pimpin'
wait.... when you drive around your boost changes... oh my god.
Old Aug 14, 2008 | 09:39 AM
03_Impreza_Al's Avatar
Don't you work at a dealership? Have them take a look at it.
Old Aug 14, 2008 | 09:41 AM
KOSTI's Avatar
Car Info: Black On Black Wingless 05 STI
Lol
Old Aug 15, 2008 | 12:11 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
Wow.....Jazz......ummmm....I'm not quite sure what to say to this.......
Just for your information....
0.1 megapascal = 14.503773801 pound/square inch
14.5 psi is how much boost your car produces stock.
edit: One question for you...what is a Muffler delete? You are running with no muffler on your car? that **** must be loud!
Old Aug 15, 2008 | 12:31 PM
technical forum?
Old Aug 15, 2008 | 12:34 PM
GotBoost?'s Avatar
Originally Posted by sigma pi
technical forum?
I'm inclined to say yes, however, I'm thinking a n00b forum might be appropriate for this one. j/p
Old Aug 15, 2008 | 12:37 PM
Old Aug 15, 2008 | 12:45 PM
Old Aug 15, 2008 | 12:51 PM
jazzml's Avatar
See thats the thing sometimes it dosent boost to 14.5 it only boosts half way.
Old Aug 15, 2008 | 12:58 PM
you are in 1st gear you wont boost 14
Old Aug 15, 2008 | 03:23 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
1st and 2nd gear boost less.
Old Aug 15, 2008 | 05:41 PM
jazzml's Avatar
That part i established but even in 3 and 4th. I reset my ecu and now it works fine its just sometimes it does that.
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
pacobeagle
Jun 16, 2003 03:10 AM
Hassassin
Nov 26, 2002 01:04 PM
Hassassin
Nov 26, 2002 11:09 AM
