06 STI only boosting 7?
Old Sep 22, 2006 | 07:40 AM
moffman42's Avatar
Car Info: 2006 WRX STI
Thumbs down 06 STI only boosting 7?
i talked to a subie tech and he said that it only boost 7psi but can go up to 15... anyone else not know that? all mags say it 14.5...
Old Sep 22, 2006 | 11:51 AM
lburrrna's Avatar
wat are your mods? whats the last thing did you do to your car lately?
Old Sep 22, 2006 | 01:50 PM
The STi peaks at about 14.5 psi. I'm not sure why he said 7 psi.
Old Sep 23, 2006 | 06:02 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
iono about you but i get 14psi hahaha. you can get about 7psi though if you full throttle on a high gear becuz it wont go any higher! something with Sti's
Old Sep 24, 2006 | 07:17 AM
moffman42's Avatar
he said that it can boost 14.5 but that when it comes off the lot that it is set for 7... that you need a boost control to get the 14.5
Old Sep 24, 2006 | 07:30 AM
pj21086's Avatar
lmao. so....does he sell boost controllers??? stock sti's hit 1 bar (14.7psi) stock. And if you ever think about getting a boost controller, dont! Get an accessport to controll your boost.
Old Sep 24, 2006 | 05:52 PM
moffman42's Avatar
yeah... i already have one on order... oh well ill just deal and upgrade later. i know the meter goes to .15 but i cant get higher than .1 most of the time .07 or 8
Old Sep 24, 2006 | 06:00 PM
.1 kPa is peak boost. It's roughly 1 bar, which is roughly 14.5 psi. You won't see peak boost 100% of the time. If the engine load is light, boost stays low, and it can be that way even if you're putting your foot into it a little, especially in lower gears.
Old Sep 25, 2006 | 07:31 AM
testes1010's Avatar
the subie tech you spoke with is a foking moron....sorry, I had to say it.
DO NOT GET A BOOST CONTROLLER!!!!
The STi from factory will boost to 14.5psi, only at WOT. If its never boosting that high there is problems with the boost control system, hosing ,etc.
Again, the subie tech you spoke with is foking moron. Don't listen to him & definately don't let him work on it.
Jeremy
Old Sep 27, 2006 | 11:09 PM
Boost Addict's Avatar
DO NOT INSTALL THAT BOOST CONTROLLER....
Were not kidding... return it SEALED....
Get a Cobb AccessPORT, let it be done properly... or... kaboom
tkarabian
Nov 10, 2006 12:17 AM
Chibby Goku
Sep 4, 2003 09:14 PM
stealth-wrx
Apr 29, 2003 10:20 AM
DriftinS14
20
Mar 8, 2003 12:48 AM
br0kwrx
Feb 10, 2003 12:41 PM
