$3,500 to spare...
Old Dec 8, 2004 | 04:05 AM
thunder_sti's Avatar
Troll
Question $3,500 to spare...
Just wondering what good quality parts and hook up can I get with $3,500 for my 05 sti. My goal is to hit low 12's maybe high 11's, how much more would I need to invest ie... godspeed stage 3 turbo upgrade etc? What you guys recommend?....
Thanks for any input...
thunder_sti
Old Dec 8, 2004 | 08:12 AM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
If your starting point budget is $3500, a good starting point would be the following upgrades:
-FP Green Turbo
-PE 850cc Injectors
-Walbro 255LPH Fuel Pump
-Helix Catless Down-pipe
-Full 3" exhaust system of your choice (Helix SS Catback, HKS Hi-power, Greddy EVO2 to name a few)
-STI UTEC (if you want to have the ability run different maps for different octane levels) or an ECUTEK reflash
These parts alone will be abit over the $3500 budget you have for now. You're going to need save more for porting the turbo (boost creep issue), installation and the all important dyno tuning time required. Also, to maximize horsepower gains, a bigger TMIC or even a FMIC should be considered down the line. Just my $0.02 in.
-Soren
Old Dec 8, 2004 | 04:36 PM
STiPilot's Avatar
Car Info: '10 WRB STi SE / '09 BMW K1300S
-FP Green Turbo
-PE 850cc Injectors
-Soren
You even need to mod the aftermarket turbo, too??? I would have hoped that if you're shelling the $$$ out for another turbo, you should just get one that works efficiently right off the shelf.
I'm thinking about getting a slightly better bolt-on turbo for my STi without having to fool around with the fuel system. I'm hoping to get a turbo that will work well without extra modifications.
Jason
Old Dec 8, 2004 | 04:40 PM
Former Sponsor
My mistake, only the stock STI turbo usually needs to be ported due to boost creep issues. FP Greens do not have to be modified.
-Soren
Old Dec 8, 2004 | 06:24 PM
vq30des's Avatar
This is exactly where im tryin to get as far as speed goes as well. So do you suggest the UTEC and ECUTEK over the Vishnu Exede. Any big differences?
Old Dec 12, 2004 | 10:58 AM
MARKSTI's Avatar
Originally Posted by little eberz
VISHNU STAGE 2 thats all you need.
nothing better and your gonna get the same parts (basicly) and SHIV tunes with a exceed which is sick compared to a reflash.
A stage two costs $5000+install or so...
Old Dec 16, 2004 | 03:01 AM
Troll
thanks much for all the input fellas.....tc..
thunder_sti
Old Dec 16, 2004 | 02:28 PM
Me&STi's Avatar
Dang... it's that much huh?!
Old Dec 22, 2004 | 04:59 PM
1/500yellowwrx's Avatar
If you want mid 12's all you need is a tbe(no cats) and a well tuned utec. That should be around $2500 with the utec tuned. I would then put some money into the suspension. Swaybars and endlinks, some pink springs and whiteline alk and you have one hell of a car. Then you will have the handling to go with the power. Some steel brakes lines and new brake pads and brake fluid would not hert either.
Old Jan 2, 2005 | 08:40 PM
mw1029h's Avatar
Car Info: 04 STi blk cloaked team blew member
Talking
I would say go with a 20g, Ecutek , injectors,fuel pump, that should but you in the mid to low 12's and it fall in you budget you will need money for the rear end you are going to break lunching at the track
Marioshi
Feb 10, 2014 12:28 PM
digableplanet
Cars For Sale
Sep 30, 2013 11:57 PM
nolan
Jul 10, 2013 12:13 PM
mulcibre
Oct 15, 2007 01:31 PM
jasno999
Dec 3, 2002 09:14 AM
