wrx turbo question
Old Mar 17, 2005 | 01:35 AM
amarpauld's Avatar
Car Info: Hyundai Pony
wrx turbo question
this question just popped into my head and I couldn't find anything by searching... so.. how long do the stock turbos on the wrx typically last?? and how much do they typically cost to replace??
Old Mar 17, 2005 | 07:50 AM
schafer's Avatar
Car Info: 03 black wrx
They should last the whole length of the cars life if you take care of them. If you are planning on keeping the stock turbo and you drive hard, I would recommend getting a turbo timer or atleast letting your car idle for around 3 minutes before turning it off completely.
The stock turbo (TD04 turbo) is around $300 to replace.
If you head over to www.deadboltspeed.com they can do a TD04 rebuild, port and polish, etc. They have a "Monster TD04" which has been ported when their "Monster Port" technology .
Here is a quote from their website:
The turbo that made us famous! We take a standard, stock WRX TD04 turbo and then let our mad scientists go to work! It gets our world-famous Monster Port(TM) process, which impoves spoolup, midrange power, lowers peak torque RPM level, and improves acceleration. Our Monster Port(TM) process was developed over a period of 2 years and included over 30 different angles, grinds, and smoothing techniques to produce the best possible results on today's Monster TD04 turbos. Also available with ceramic coating, compressor housing outlet port, and compressor wheel upgrades.
The monster TD04 starts at $400
As for installation of the turbo if you plan on replacing it yourself.. It should only take around an hour to two hours at max. Refer to this TurboXS' guide to installing turbochargers yourself:
http://www.turboxs.com/Stage%204%20I...structions.htm
For more information about upgrading the turbo and also some general information about the WRX turbo, read this faq put together by Unabomber over at Nasioc.com:
http://forums.nasioc.com/forums/showthread.php?t=555332
Hope this helped
-Steve
Old Mar 20, 2005 | 09:37 AM
troll's Avatar
Car Info: 2002 WRX
Subaru says that the stock turbo does not need a cooldown period (see the following post for more info). Most modern turbos seem to do just fine without cooling down.
http://forums.nasioc.com/forums/show...hreadid=465156
rallied out wrx
May 23, 2006 12:50 PM
Dirty Sanchez
Dec 28, 2005 02:08 PM
WrsExX
Mar 30, 2005 06:54 PM
bluesubeguy
Oct 4, 2003 03:26 PM
singsing
May 24, 2003 03:19 AM
