up pipe installation
Old Mar 6, 2005 | 08:23 PM
ankisWRX's Avatar
where in southern cali do u think i can get an up pipe installed for a good price? i called pann auto and they would charge 400 dollars. thanks
Old Mar 7, 2005 | 09:22 AM
liquid_sword's Avatar
Car Info: silver 03 rex
damn 400 bills to install thats just crazy i installed an uppipe in my wrx and trust me its a pain in the *** but..well worth the money you will save. oh yes i would have one of your friends help you out. i belive that scoobymods.com should have detailed installs on their site. good luck
peace
Old Mar 7, 2005 | 09:59 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Here you go
http://www.scoobymods.com/forums/showthread.php?t=194
The only other thing is get some 2.0 resistors from radio shack and put a bolt in the EGT bung to block it off, I don't know the size of the bolt but I'm sure some one could post it please.
Old Mar 7, 2005 | 12:20 PM
ankisWRX's Avatar
yeah i wanna try to install it myself but my freind thinks itll be really hard cuz of the bolts i would have to bolt on and off, but i guess its worth 400 bucks lol thanks guys
Old Mar 10, 2005 | 05:00 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
4 bills is TOO MUCH ! shops over here do it for 140ish (Nor-Cal) . . . just get a bunch of friends to help you. save your *** some money ! start as early as possible !
Old Mar 10, 2005 | 09:33 PM
Smooth_Ej20's Avatar
Car Info: 2004 Wrx
400 bucks sounds like a lot but if you look at the way they would do it it isnt that much. THe shop would most like remove the turbo and intercooler and all that junk but you dont need to. Heres what you should do. Remove the DP, loosen up the up-pipe screws on the turbo, you're gonna have to remove some of the heat shield and ex manifold pieces. Loosen the ps motor mount and jack up the engine. its gonna take about 2.5 inches to get the factory up-pipe out once you do that re attach the motormount. You're new up-pipe should slide right in. Good luck man, it took me and my friend about 4.5 hours to put my ex manifold and up-pipe on in my garage.
Old Mar 10, 2005 | 09:45 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
$400 is a downpipe man. Do it yourself. It'll be tough, but well worth it. I did it in 'installments' of work over 3 days. I got stuck a few times, but in the end I prevailed. All by my lonesome too.
Old Mar 10, 2005 | 10:49 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
It's not that hard.
Old Mar 11, 2005 | 02:22 PM
Jumpman23's Avatar
Originally Posted by VIBEELEVEN
It's not that hard.
depends how good you are with cars too tho . . . if you're a noob to modding it'll be a PITA !
Old Mar 11, 2005 | 03:01 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
12 step uppipe program
1. put the car on stabile jackstands
1.5 make sure you have an 02 sensor wrench
2. take off front right wheel
3. take off plastic undertray splashguard
4. take off intercooler
5. take off turbo heat shield
6. spray downpipe bolts with a liberal amount of liquid wrench or wd40
7. take off downpipe
8. spray uppipe bolts with a liberal amount of liquid wrench or wd40
9. take out egt sensor
10. unbolt passenger side engine mount, push up engine (it's not that heavy) and wiggle the stock uppipe out. (after you unbolt it uf course).
11. Replace with FLEX uppipe
12. Repeat steps 10-1 (and when you put the intercooler back in it's easier to slip the ypipe onto the turbo and just bolt the flanges to the i/c
Old Mar 14, 2005 | 05:25 PM
troll's Avatar
Car Info: 2002 WRX
2 suggestions:
1) Get new gaskets - a whole new 5-piece kit ($59 from subydude).
2) Use a flex uppipe
Otherwise, be prepared to do it again if/when it leaks.
Old Mar 14, 2005 | 10:05 PM
NoMoHonda's Avatar
Take it Aerosim in Costa Mesa, i onno to me uppipe not worth the pain without a lift and all the proper tools, might as well put a downpipe and an EGT gauge at the same time.
Old Mar 17, 2005 | 03:47 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
You don't need a lift, as for the downpipe, you have to take it off in order to get to the bolts on the uppipe.
Old Mar 19, 2005 | 05:51 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
should be like 150 for install
Old Mar 20, 2005 | 10:17 AM
Car Info: 2004 Wrx
to go along with Vibeeleven when you get the up-pipe off there are two bolts on it that go to the back of the turbo, if your new up-pipe comes with the bolts seperate when you go to put them on put them on facing down so when you put the nut on you can access it from the bottom. That way, if you have to take it off you wont have to remove the down-pipe.
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
spdkills
Jan 18, 2003 08:32 AM
