Why is the USDM EJ20 an open-deck block?
Old Nov 24, 2003 | 11:39 PM
caterpill's Avatar
Car Info: Rust bucketo
If japan has always had closed-deck EJ20 engines on their WRX's, why is it that the USDM has to get a redesigned open-deck EJ20? As far as I know closed-deck engines are always supposed to be more reliable with a forced induction setup.
Did the japanese-spec engines have some sort of gasket problems or something? Is it just for better cooling?
Are the new-generation WRX's in japan still sporting a Closed-Deck Block, or is it similar to what we have now in the US?
I just read another topic on the STi's semi-closed deck design and these questions popped in my mind.
Any insight will be appreciated.
Dan
Old Nov 25, 2003 | 12:36 AM
supermarkus's Avatar
Follow this link. All you need to know is right here
http://www.spdusa.com/new_page_4.htm
Newer JDM WRXs have the same ej205 we have, with little tweaks like higher compression and AVCS. It isn't only the USDM GD WRX that has been stuck with this engine.
Old Nov 25, 2003 | 12:41 AM
The new STi has a semi-closed deck, not an open deck.
that one legacy
Oct 12, 2008 09:27 PM
scooby2.5i
Oct 12, 2006 06:02 PM
Imprezer
May 28, 2003 03:08 AM
Imprezd
May 19, 2003 07:12 PM
