White/blue smoke?
Old Oct 20, 2006 | 01:13 PM
forcefed's Avatar
White/blue smoke?
02 WRX, 64500 mi., running Utec stage 2, Bosel cat-less up-pipe, TXS cat-less downpipe, high-flow cat, Blitz axle back. Have recently noticed a little white/blue smoke from exhaust, thinking it's my turbo. Smoke looks the same as on my Eclipse when that turbo needed replaced. Any suggestions on how to diagnose before I have to pay to have it looked at? If it is the turbo I can install it my self.
Old Oct 20, 2006 | 01:31 PM
Anti-hero's Avatar
Car Info: Subaru PSM Wrx 05 w/ Mud guards Red 88 Conquest
If idle is ok pull spark plugs if normal,=turbo seal gonners.
If idle bad and plugs show oil or is wet with coolent =engine gonners.
Old Oct 20, 2006 | 01:45 PM
forcefed's Avatar
Have not checked plugs yet but idle is rock solid, Turbo seals are what went in the Eclipse.
Old Nov 12, 2006 | 10:10 AM
sonicyellowtech's Avatar
Car Info: 03 sonic yellow wrx
hows oil consumption, thats a big deciding factor in a diag. like that. blueish tint smoke is going to be an oil consumption problem. if you are seeing white color smoke check coolant level. monitor them closely and then go from there
Old Nov 12, 2006 | 10:12 AM
zumnwrx's Avatar
when do you notice the smoke? after its warmed up? at start up? while driving?
solidace46
Sep 9, 2010 10:08 PM
Andri WRX
Aug 26, 2007 07:44 AM
bluesubeguy
Dec 31, 2003 07:24 AM
midnightwrx
Dec 11, 2003 07:41 AM
DoomE.Q.
Wanted
Oct 28, 2003 04:07 AM
