blue smoke ?
Old Aug 25, 2007 | 08:23 AM
Andri WRX's Avatar
Car Info: Subaru Impreza STi 2006
blue smoke ?
hæ tear ... i have a 06 sti 2,5 euro my sti has 37Þ kM or 23 K miles
100% oil servise ....5-40 full syntetic oil
but heir is the problem the engine burns about 1 líter of oil ,Every 1000 km or 625 miles
ven i start the car thear comes a blue smoke djust for 3-5 sec but nothing more ....ven cold
what is wrong ... some mods on the exhust ..boosting about 15-16 psi
my first post
Old Aug 25, 2007 | 01:49 PM
03_Impreza_Al's Avatar
Blue Smoke means you are burning oil.
Old Aug 25, 2007 | 02:01 PM
wrxisthebest's Avatar
ya i get it to some times!
it is cause u are burnin oil
if i let my car idle for a while then hit the gas i get oil smoke out my exhaust!
Old Aug 25, 2007 | 02:03 PM
^ yah oil is getting into the cylinder.
Do you check your oil often?
Old Aug 25, 2007 | 02:04 PM
very often!
Old Aug 25, 2007 | 02:09 PM
Are you losing oil?
Old Aug 25, 2007 | 04:37 PM
Wingless Wonder's Avatar
Visible blue smoke means oil is getting into the combustion chamber, either past the piston rings or from leaking valve seals and being drawn down the valve stems from the top of the cylinder heads. A compression test might be able to tell you which cylinder is the worst offender but a leakdown test using a gauge and compressed air can narrow it down further.
Old Aug 25, 2007 | 06:05 PM
Andri WRX's Avatar
then its not the turbo ... leeking ? or is theat out of the question ?
Old Aug 26, 2007 | 03:44 AM
The turbo could have a failing oil seal. If that's the case, a compression or leakdown test will not find the problem. I'm not sure how to diagnose a failing oil seal except by removing the turbo and inspecting it.
Old Aug 26, 2007 | 07:44 AM
it is my turbo!!
that is why i get oil sumtimes!
ill see 03 impreza al today and ill speak to him bout it but ery one i talk to says it is my turbo!
solidace46
Sep 9, 2010 10:08 PM
forcefed
Nov 12, 2006 10:12 AM
DoomE.Q.
Wanted
Oct 28, 2003 04:07 AM
planethub
Dec 10, 2002 06:52 PM
