Whats wrong here...
Old Dec 20, 2003 | 10:16 PM
ScoobyBoy's Avatar
ive got the same tt as you and just to clearify a bit, 1 bar = 14.5 psi. what we have is hkpa. i forget the conversion but i think its something like 13.2psi = 1 hkpa? its something like that.
getting 1.09 is really good already. the most ive ever gotten was 1.1 but that was due to a spike with the restrictor mod you are thinking of. the lack of boost suddenly should be normal. since its raining and the air is colder.
in regard to the restrictor mod, stay away from it, it causes the turbo to spike too much.
gluck and enjoy the car
Old Dec 21, 2003 | 02:20 AM
AzN121184's Avatar
Car Info: civic
yes, what racerz22 said, when the weather is cold, or when u drive in cold conditions, u tend to boost 1 more psi above the usual psi you get, which would probably explain why
Old Dec 22, 2003 | 12:55 AM
Re: THANKS!!!
Originally posted by WRX_scott
Thats what I thought. But say if I go to Palmdale with an elevation of 2800+ ft above sea level and I race. I know the lack of air effects the way the turbo runs but with it being as cold as it is now would that hurt the car performance?
Scott
The colder the air is, the denser it is, so when it passes through the compressor and gets heated, it expands more than warmer air would have, causing more boost. Basically, it just means more air to make more power with, without your engine having to do any more work to get it. If you don't have mods, you don't have to worry about any damage simply due to the weather conditions, although performance can greatly vary.
Old Dec 11, 2004 | 10:15 AM
de pilipino guy's Avatar
Car Info: none
so hkpa is pretty much the same as a bar?
Old Dec 11, 2004 | 09:44 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I have a Blitz DTT turbo timer and when I called Blitz USA they (like most people) said hkpa is the same as bar which would mean 1 hkpa=around 14.5psi. I have also seen companies claim it can read up to 2.5 hkpa (36.75psi) and that would mean that 1 hkpa=14.7psi so who knows for sure.
Old Dec 12, 2004 | 11:12 AM
Car Info: none
thanks alot dude that really help... one more question those 4 different boost settings at what number do guys have it at(i have the dual sbc spec s)....and what would 1.20 and 1.30 hkpa be psi, i think it's 18 and 19 right(correct me if im wrong)..
Old Dec 12, 2004 | 12:34 PM
MO REX's Avatar
I have never run a boost controller so I don't know much about them but those #'s sound too high for a WRX that only has a boost controller. If you are running that much boost, have you hit fuel cut off?
I converted those #'s in the other thread and your guess is close.
WrXaWd
Jan 17, 2004 01:14 PM
LUV2XLR8
Nov 23, 2003 01:51 PM
02silversuby
16
Oct 28, 2003 01:36 PM
02silversuby
Oct 27, 2003 01:01 AM
pepsi_blue
Jun 27, 2003 06:01 PM
