What should used spark plugs look like?
Old May 12, 2006 | 03:16 PM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
I just pulled my spark plugs to replace them and was wondering what normal wear on a plug would look like, mine have kinda fluffy white deposits on them.
To my understanding the white deposits are normal, I just wanted a second opinion.
TIA :banana:
edit: after further inspection it is more of a brown/grey deposit
Old May 13, 2006 | 08:57 AM
Keisatsu's Avatar
Well, nevermind... found all the info I needed in my WRX shop manual. Tan/Brown deposits mean the fuel is burning A-OK!
:banana:
Old May 13, 2006 | 08:33 PM
Wingless Wonder's Avatar
I found a photo of an old NGK used spark plug chart that someone scanned and posted on their site. In modern fuel injected cars, you would rarely see the extreme examples of overly rich or oil fouled plugs unless something is mechanically wrong with the engine or tuning.
Forget ever cleaning spark plugs using a small grit-blasting tool that is sold in some places. By cleaning plugs with abrasive grit, it raises the voltage requirement to fire the spark plug using the same gap. If the plugs look that worn, chuck 'em and replace with brand new ones. Copper center electrode spark plugs are cheap and work well but replace regularly because the center electrode wears quickly with performance use. After a few months, you can actually see the shape of the electrode become rounded off at the tip so that it no longer resembles a cylinder shape.
Old May 13, 2006 | 11:34 PM
Keisatsu's Avatar
Mine were prolly looking between 14 and 19 on the chart (spark plug chart ftw btw)
I just replace my plugs w/ stock type plugs, they last a long time and I am not running higher boost so I don't need better/higher grade plugs anywho.
Bagin,DVS
Mar 25, 2008 10:22 AM
kenight
Jan 15, 2008 05:55 PM
DetailAddict
Oct 21, 2005 03:11 PM
SubieDo
Jan 31, 2005 06:23 PM
SHADO
Mar 8, 2004 06:59 AM
