what should be my next mod ?
Old Feb 27, 2005 | 02:59 PM
subablunc's Avatar
Car Info: WRX 04
Hi,
Wonder what my next mod shoul be. My setup :
- full TBE with UP
- APSCAI
- VF34 + STI injectors + FP
- AVC-R @ 1 bar (A) and 1.35 bar (then decreasing)
- ~ S-AFC (DIY).
Should it be :
- FMIC (afraid of lag and is the VF34 "big" enough ?) ?
- headers (don't want to lose the boxer sound) : 4-2-1 or 4-1 ?
- turbo inlet hose ?
- lightened flywheel to have a lighter car ?
Thanks.
Old Feb 28, 2005 | 07:05 PM
subablunc's Avatar
Car Info: WRX 04
no reply ? why ? I can't do any "search" on this !
Old Feb 28, 2005 | 07:57 PM
fastnoypi's Avatar
depending on your heat conditions.. of your list the FMIC in my opinion is the only worthwhile next mod. the vf34 is fine..turbo selection really is determined on your budget.
there are plenty of DIY mods that are free or very cheap that give some noticible gains.
ie, grounding mods, exhaust and intake manifold port matching, throttlebody port, throttle bodycoolant bypass, etc..
Old Feb 28, 2005 | 08:20 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I'm no expert on the subject but I would think alcohol injection and a dyno tune would make a big difference http://www.smcenterprises.com/subaru.htm. For safety an egt gauge would also be a good Idea.
Old Feb 28, 2005 | 09:29 PM
subablunc's Avatar
Car Info: WRX 04
I'm planning on purchasing Zeitronix kit.
FMIC becomes necessary (because of heat).
Old Mar 1, 2005 | 07:13 AM
fastnoypi's Avatar
You'll definitely get some good use out of the WB kit.
I havent seen the Zeitronix in person. im eyeing the innovate wb though it is bulky for mounting.
Old Mar 1, 2005 | 07:25 AM
deks's Avatar
Car Info: silver wrx
Hi,
- full TBE with UP
- APSCAI
- ~ S-AFC (DIY).
Should it be :
Thanks.
Big brakes to support that power? Suspension?
Old Mar 1, 2005 | 12:52 PM
subablunc's Avatar
Car Info: WRX 04
I already have Ferodo DS2500 pads + braided steel lines + AP Racing fluid.
I was asking which part for power ? I never forgot to upgrade handling and brakes
Old Mar 2, 2005 | 01:52 AM
kumaWRX's Avatar
Car Info: 04 Toyota Tacoma
As for the headers, you'll only lose the boxer sound if you get equal length headers. The stock, as well as most aftermarket headers, have two long manifold pipes and two shorter ones because of the flat 4 design. Only if you get equal length headers will you lose the rumble.
Old Mar 2, 2005 | 06:02 AM
fastnoypi's Avatar
Originally Posted by kumaWRX
As for the headers, you'll only lose the boxer sound if you get equal length headers. .
you'll also lose low end spool time with headers...headers will actaully move part of the powerband up further the rpm range...in most cases a 500 rpm difference in spool time
WikdRX
Feb 28, 2005 09:09 AM
Sevielle
Jun 4, 2003 07:20 AM
NRTmotorsports
Jun 4, 2003 02:26 AM
Mach5WRX
Apr 23, 2003 11:34 PM
Kevin02REX
Mar 16, 2003 03:21 AM
