What oil do you use?
Old Apr 27, 2008 | 12:59 AM
WRX409's Avatar
Car Info: 04 WRX
What engine oil do you use in your car and
have you notested any oil consumption problems
with the oil you use?
I have had a oil consumption problem since I bought my
car and the only thing that helps is useing Castrol 10W30
motor oil when doing my oil changes.
Old Apr 27, 2008 | 01:06 AM
grewal06's Avatar
Car Info: 06' 280whp/300wtq pig nose and 05' porsche cayenne
i use mobil 1 10W30 Full Synthetic and what ever oil paul at db tuned uses on my car. i havn't had any consumption problems yet. i mean i've heard wrx's use more oil then other cars but i havn't noticed anything different with mine.
grewal06's Avatar
y, and how much does yours consume?
Old Apr 27, 2008 | 01:36 AM
WRX409's Avatar
Car Info: 04 WRX
I change my oil every 2500-3000 miles.
My 04 WRX consumes 1--11/2 quarts every oil change.
Subaru says that it's normal and to try useing a thicker motor oil.
Once I found that I had no oil in engine and the dipstick was
bone dry.Now I keep taps on my oil and check it every day.
Old Apr 27, 2008 | 04:06 PM
WRX409's Avatar
Car Info: 04 WRX
Could bad piston rings be the culprit?
Old Apr 27, 2008 | 04:29 PM
DemonPossessed's Avatar
Car Info: 05 wrx
when I first got my car i started to use mobil one 5 30
i noticed by the time i got to 3000 miles i would be low almost a quart.
since then I switched to redline 5 30 and I hardly consume any oil now.
i'm not sure.......
Old Apr 27, 2008 | 04:48 PM
Egan's Avatar
Dino 5W30 in my 02 WRX wagon. 3X,XXX miles when I traded her in and she never burned a drop of oil. That car was making 260 whp on a VF30 and supporting mods.
Dino 5W30 in my 04 STi. 19,XXX miles when I sold her and she never burned a drop of oil. That car made 279 whp on a TBE and tune.
Dino 5W30 in my wife's 05 LGT. 45,XXX miles to date and she has never burned a drop of oil. This car is basically stock.
Both the WRX and STi had multiple track days on them.
Old Apr 27, 2008 | 04:52 PM
grewal06's Avatar
it could be the piston rings. have a professional check it out. you don't want to pay to much later on down the line.
Old Apr 27, 2008 | 05:24 PM
WRX409's Avatar
Car Info: 04 WRX
Yep I agree.
What's funny is when I first bought my car I was running 5W30
Mobil 1 and the oil consumption was worse.Now I'm running the
thicker dino Castrol 10W30 and the oil consumption problem isn't
as worse.
Old Apr 29, 2008 | 07:36 PM
HAT3R 671's Avatar
From: in a grass hut on the mountains next to Walmart
Car Info: 05 Aspen White STi wid 2 AK47's in da trunk!
i use royal purple 10W30
i haven't notice any over excessive il consumption problems.
Old Apr 29, 2008 | 09:38 PM
WRX409's Avatar
Car Info: 04 WRX
I am going to live with the oil consumption issue.
If my EJ20 engine bits the dust it will be a great reason
to upgrade.
The thing is my engine runs fine without any signs of wear
so I will be keeping it.
After alot of research I found that bad valve seals or bad piston rings
could be the source of the problem.
Old Apr 29, 2008 | 09:43 PM
not12listen's Avatar
Car Info: 06 WRX Wagon
i've used mobil 1 10w30 and castrol gtx 10w30.
my RS goes thru roughly 1 1/2 quarts every 2500 miles. it seems like a bit much to me... i'm going to try some other oils soon enough, and comment back with my findings.
darkonion
63
Apr 17, 2009 08:25 AM
Jake
Jan 5, 2008 01:55 PM
Rad One
Apr 12, 2005 08:04 PM
leechungsr
Mar 16, 2005 03:51 PM
ruza
13
Mar 13, 2005 02:01 PM
