What motor oil is everyone using in their Rex?
Old Jan 1, 2005 | 06:29 PM
  #91
MO REX's Avatar
Car Info: 02 PSM WRX
I've been using 5w30 Castrol syntec but I just won a case of Royal Purple from a Subiesport drawing so I will be using that for awhile.
Originally Posted by bpang1
where did you find RP in Hawaii?
For tranny and diffs I intend to copy the subaru rally teams and use Neo...I've been having problems getting into first unless I go down to like 5 mph.
I'm sure you have figured this out by now but if you didn’t here is a link http://www.royalpurple.com/dealers/hia.html.
If the Neo doesn’t work for you check this out https://www.i-club.com/forums/showth...ght=syncromesh.
Old Jan 2, 2005 | 05:20 PM
  #92
cohlineman's Avatar
From: At the store trading the box of tissue in on some brawny!
Car Info: Platinum 02 WRX, Progress springs,JIC Bullet exhaust , STI shifter, Accessecu, Rota Sub Zero
OEM filters and Mobil 1 synthetic, new vehicle formula.
This is a superior oil to Red Line , Motul and other fancy oils because of one resounding fact....
they sell it at Costco!
Old Jan 3, 2005 | 09:32 PM
  #94
ThrilRyder's Avatar
I have an 04 wrx that just turned 10k, is it to late to switch to synthetic from dino?? Should I start out with M1 or go strait to Royal Purple???
Old Jan 3, 2005 | 09:34 PM
  #95
Damon's Avatar
Car Info: 02 White WRX Wagon
gtx
Old Jan 3, 2005 | 09:57 PM
  #96
Steven@Coach's Avatar
Car Info: 2011 WRX Hatchie
Engine - Mobil 1 Synth 5-30
Tranny- Pennzoil Syncromesh dont remember weight
LSDs - Redline LSD gear oil 75-90
Old Apr 30, 2005 | 11:29 PM
  #97
knightsnke's Avatar
Car Info: 2003 WRX
Quaker State 5w-30 synthetic plus Lucas Oil Stabilizer aka STP
Old May 3, 2005 | 12:06 AM
  #98
black02's Avatar
Car Info: 02 WRX
Mobile 1 5W30 synthetic
Old May 3, 2005 | 12:37 AM
  #99
jeff2417's Avatar
Car Info: 2007 NBP FA5 Si
yeah that...minus the Lucas Oil Stabilizer. Oh, and minus the rex. I own an RSX-S.
This stuff is really good so far..I've used red line since oil change 3, and Mobil one every oil change since. This gives me a lot more low and midrange power than either one of the previous brands...we'll see how long this effect lasts, I burn a quart of oil about every 1500 miles! Goddamn 8100rpms...you're the death of my oil! BTW, I use GM Synchromesh Tranny fluid w/friction modifier...like BUTTA!
jeff2417.
www.qpower.com
Old May 3, 2005 | 08:29 AM
  #100
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
jeff2417.
www.qpower.com
1 Quart in 1500 miles? You're kidding, right? If not, I'd like to find which oils you used since new (and your driving style during break-in) so I can add it do the list of "don't EVAR do that/ use that" list!!!!
Old May 3, 2005 | 09:50 AM
  #101
jeff2417's Avatar
It's not the oil, it's the car. RSX-S's burn a LOT of oil; depending on how you drive. I happen to redline quite a lot, and hence the result of a quart for every 1500.
Old May 3, 2005 | 10:01 AM
  #102
tsubaru02's Avatar
Car Info: 06 sti,03 wrx,06 leggy 2.5i
mobil 1 the best there is .i use it and still change my oil every 3 month
Old May 4, 2005 | 07:28 PM
  #103
subywrx's Avatar
regular 5w-30 with oem oil filter. Just what the book says.
Old May 10, 2005 | 09:53 AM
  #104
jonsWRX's Avatar
Car Info: 05 WRX
i use Mobil 1 5w-30 but summer is coming up should i switch my oil to be thicker like 10w-30 or should i leave it at 5w-30 year around?????
jon-
