What motor oil is everyone using in their Rex?
Old Mar 16, 2004 | 04:03 PM
Need4Boost's Avatar
Car Info: GDA w/ RA-C & TO4E
Mobil 1
Motul
Amsoil
Old Mar 16, 2004 | 05:17 PM
r_master's Avatar
Car Info: PSM WRX
i recently changed my oil from mobil 1 to redline (both 5w30). some things i realized...
-mobile 1's oil pressure was at 2.0ish (bar) during idle after it reaches its operating temp.
-redline's oil pressure is at 2.5ish (bar) during idle after it reaches its operating temp. (almost like as if i put mobile 1 10w30 oil).
-mobile 1's oil temp was at around 90 degrees when the oil was fully heated at idle. when driving hard, i saw it go upto 120 degrees.
-redline's oil temp is at around 100 degrees when idle, but never reaches 120 degrees like mobile 1. and it took a lot longer to get the oil temp to reach the normal operating temp.
there are other differences i see when driving hard, but i need to look at my guages more carefully to give you any type of data on that.
i don't know if the above data means something... maybe i need more data??
at least to me...
redline takes longer and takes more heat to heat up, but has higher operating temp... maybe someone can tell me if i am wrong or not?
edit: it was BAR not PSI
Old Mar 16, 2004 | 07:09 PM
thebankman's Avatar
Car Info: subaru
mobil 1
Old Mar 16, 2004 | 07:52 PM
Cleric's Avatar
Car Info: '04 WRX
Does anyone know were one could buy/ order Motul? would love to use it but can't be found anywhere
Old Mar 17, 2004 | 06:00 AM
Captain Ned's Avatar
Car Info: '02 WRX Wagon
Mobil 1 5W-30 in winter, 10W-30 in summer.
Old Mar 17, 2004 | 08:12 AM
wrx21's Avatar
Car Info: 2004 Impreza WRX
5w-30 Castrol Syntec
Old Mar 17, 2004 | 09:48 AM
fanker's Avatar
Originally posted by redrex
Mobil 1 synthetic here too...
Old Mar 17, 2004 | 10:28 AM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
You should use something like 20w-50 in summer, especially these HOT Sac. valley summers.
Old Mar 17, 2004 | 01:17 PM
forcefed's Avatar
I've been using Valvoline synthetic, was told by a local shop that it is the same as Mobile 1, comes out of the same vat. Can anyone verify this? I also used it in a Mitsu GST since thats what the Mitsu dealer recomeneded.
Old Mar 18, 2004 | 12:59 AM
tim's Avatar
tim
Castrol Syntec 5W-50 here in hot So. Cal... I like the extra protection and extreme versitility it gives me.
Old Mar 19, 2004 | 01:25 PM
cnk's Avatar
cnk
Mobil 1
Calvin
Old Mar 19, 2004 | 03:00 PM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
another Mobil-1 5w30 with OEM filters
Old Mar 19, 2004 | 03:10 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Mobil 1 syn since 1,000 miles.
Old Mar 19, 2004 | 04:28 PM
Wrxneffect's Avatar
Car Info: 03 Wrx black sedan + 2013 BRZ
Check here: http://www.ltbmotorsport.com/motul.html
This is where I got my Motul transmission fluid, I currently use Mobil 1 in the engine and Motul in the brakes.
Jason
