What I think I Know VRS The Truth, FMIC's.
Car Info: '02 WRX TurboXS Stage 4
O.k. folks, what are your thoughts on this?
It is my understanding that FMIC's, while adding more HP will increase lag. I'm pretty sure that plumbing diameter makes a difference in the amount of time it takes to build up pressure get a good response from the motor. The next logical jump would be that the increased distance required for that air to travel to and from an FMIC would necessitate a pressure drop and also cause more lag, not necessarily "turbo lag" but a lag in power either way. Is this a correct assumption?
Yes, that is true. That's why you shouldn't get a huge FMIC with a small turbo. If you don't flow enough CFM's, the FMIC will actually be a hinderance to your performance. It's better to go with a TMIC for a small turbo like the stocker or a VF series. But if you have a PE1820 or anything bigger, then for sure you can benefit from a FMIC.
Andersonwrx
13
Dec 31, 2002 06:29 AM
