Water Bubbling Sound at startup
Old Jan 20, 2004 | 01:54 PM
stevedood's Avatar
Car Info: _
OK...
does anybody know if the WRX has an in-dash bong system?
Seriously...
When I start my car up in the morning and give it a little gas, I hear a water/bubbling/liquid sound kinda coming from the dashboard area. The sound goes away after I rev the engine abit but usually is there again at the next startup.
I was wondering if this is related to the coolant or AC system?
I checked my coolant and thought maybe there was a bubble in the lines and I was abit low on coolant so I filled up the reservoir thinking that this might have been the issue. I'm not sure if this fixed the problem because the gurgle-sound was there this morning again, just not for as long of a time.
There are no noticeable changes in performance, car has roughly 50k miles on it.
I was also think maybe I had some standing liquid inside my intercooler (oil, water?). Maybe the condenser reservoir has liquid in it?
Anybody else have any ideas?
Thanks.
Old Jan 21, 2004 | 06:38 AM
wrxman69's Avatar
Car Info: 2003 WRB WRX sedan
Same thing here my '03....
My guess is flowing through the heater? Air bubbles?
Thought about calling the dealer on this one, but it seems
harmless enough.
Funny thing is it didn't always do it....not till about 15,000
miles or so.
Old Jan 21, 2004 | 01:52 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Make sure you're full of coolant. When the car is cold, open the reservoir and top it off. Start the car and let it idle until the fans come on (the reservoir should make a slurping sound when the thermostat opens), keep topping the reservoir off until it stays full. Also gently squeeze the top radiator hose to get rid of any bubbles.
Good luck
Old Jan 22, 2004 | 02:51 AM
supra_man's Avatar
are you sure that your headers are attached to your engine still??? Cause we just installed headers on my friends RS so we figured while there were no headers on we wanted to know what it sounds like when we drive. blub.blub,blub
Old Jan 22, 2004 | 09:25 AM
stevedood's Avatar
Car Info: _
A friend was saying it might be the tranny fluid?
Is this a possibility?
Old Jan 22, 2004 | 11:37 AM
esracer's Avatar
Car Info: 2002 Honda S2000
My civic had something like this too, i thought it was weird but i didn't think too much of it.
Old Jan 22, 2004 | 02:40 PM
BlingBlingBlue's Avatar
Mine does it too. I think there is a tiny bit of air in the coolant. I've tried topping off, as detailed above, but with no luck. From what I've heard, it is easy to get an air bubble in the cooling system of a Subaru motor.
Old Jan 23, 2004 | 03:53 PM
stardogchampion's Avatar
Car Info: WRX
mine does it, i think it is the fluid flowing for the heater..and its heard from inside the car.
Old Jan 23, 2004 | 10:27 PM
ScoobySaurusRex's Avatar
yea i'm pretty sure it's the coolant flowing through the heater element. could also be bubbles in the system, I only heard the sound after I emptied and refilled my system after the turbo install.
Old Jan 24, 2004 | 12:11 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
Re: Water Bubbling Sound at startup
Originally posted by stevedood
OK...
Thanks.
mine has been clean for 12000 miles now... actually after i took it in to my service dept... *poof* its gone. . . my friend keith did that thing dat mex pizza said. . . i was kinda freaked @ 1st. . . now i check my coolant(n evryting else) weekly just to make sure.
ASpec818
Jan 3, 2007 12:42 PM
stevedood
Jan 21, 2004 01:53 PM
pcconsultant
Dec 6, 2003 08:04 AM
AWDcamera
Apr 7, 2003 07:01 PM
WRXRON
Mar 27, 2003 05:35 AM
