bubbling sound from engine from stop and go driving
Old Jan 3, 2007 | 08:17 AM
ASpec818's Avatar
Car Info: Audi B6 S4
i noticed a bubbling sound from my engine after long periods of stop n go driving. it happens after i start me engine and goes away in like 10 seconds. is this anything to be concerned? also, i notice my idle revs increasing everytime im in traffic. normal revs are at 500rpms and when im in traffic, it would jump to around 1500 rpms and stay there.
Old Jan 3, 2007 | 08:19 AM
midnitewrx02's Avatar
Car Info: 2006 CGM WRX
sounds like maybe your coolant esevoir is boiling over.. are you overheating?.. and maybe you have a vacuum leak?
Old Jan 3, 2007 | 08:39 AM
STiYLIN's Avatar
wouldn't that register on the temp gauge?
Old Jan 3, 2007 | 09:19 AM
BlingBlingBlue's Avatar
Does it sound like a hookah or bong? My car did that for a bit...it went away after I topped off the cooling system. Try this: when the car's cold, open the cap and squeeze the top radiator hose several times to "burp" the system. Then top off with distilled water or coolant.
Old Jan 3, 2007 | 09:40 AM
STiYLIN's Avatar
bingo! I bet he has coolent bubbles and you are hearing it in the heater core possibly?
Old Jan 3, 2007 | 09:51 AM
ucbsti's Avatar
Car Info: 2006 evo IX
its the blinker fluid getting hot
Old Jan 3, 2007 | 10:19 AM
Snot Rod's Avatar
Car Info: .
If the coolant level is too low, the sensor wouldn't touch the water and give a false reading. My mom blew the head gasket on her '84 Tercel 4WD wagon twice because of that same reason.
Old Jan 3, 2007 | 10:28 AM
STiYLIN's Avatar
hence the reasons for defis (or any other "real" gauges)
Old Jan 3, 2007 | 10:37 AM
same kidnve deal happened with my 1st car, 92 civic 4 dr (1.5L powah!!)...i knew it was overheating but the gauge never said so.. until AFTER the HG went, then the gauge told me it was overheating
Old Jan 3, 2007 | 11:22 AM
Snot Rod's Avatar
Car Info: .
I think Defi's would have been overkill for that application. :rotfl:
Anyhow, it did have a gauge (of sorts), not an idiot light. It would only run at 1/3 up the guage when the level was low, instead at 1/2 way when the coolant level was good.
Old Jan 3, 2007 | 11:49 AM
STiYLIN's Avatar
Why is a Defi overkill, it could save your motor and if you already have the controller for other gauges (ie oil temp, egt, boost) then why not? Idk but my 4th gauge will most likely be the amber bf water temp gauge.
Old Jan 3, 2007 | 12:42 PM
Snot Rod's Avatar
Car Info: .
I was referring to Defis in my mom's Tercel.
stevedood
Jan 24, 2004 12:11 AM
stevedood
Jan 21, 2004 01:53 PM
pcconsultant
Dec 6, 2003 08:04 AM
turbo022
Jul 16, 2003 05:13 PM
AWDcamera
Apr 7, 2003 07:01 PM
