Bubbling sound from the engine...
Old Apr 5, 2003 | 11:31 PM
Wingless Wonder's Avatar
Originally posted by AWDcamera
I have not found any leaks nor has there been any evidence of a leak at all so i'm pretty sure i'm not loosing coolant but for some reason it tends to get low after a couple months of driving. Is this normal? Also has anyone else heard this bubbling sound?
I don't have this sound and I don't lose much coolant, even over a long period of time. Without hearing the sound or seeing your car for myself, I wonder if you've got a blown head gasket? You might then lose coolant into the cylinder and out the exhaust. I hope this isn't the case.
Know anyone that has a leakdown tester (and knows how to use it) and an air compressor?
Old Apr 6, 2003 | 10:36 AM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
I have had a similar prob on a different car -
One car had a very small hole in the plastic part of the radiator - I couldn't find it until I filled the car while it was hot and the water shot out of it but the radiator was never waterless however I did notice that I would run hotter than normal during summer days in stop-and-go traffic.
Old Apr 6, 2003 | 02:33 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
I have this problem too.
Gino's ( And Also Dave's Friend James) Advice:
In the morning, pop the hood. Open the radiator cap, and now start the engine, let it idle, and also turn on the heater on full heat and full blast. Now let it sit and idle, until it gets to proper temp. Watch the fluid in the radiator... If bubles come out at any time, you have air in the system, and most of it just leaft the system. I am getting air into my system now and then, and I'm having to do this like 2 times a month, letting air out. If the fluid level drops a lot, add some coolant straight to the radiator... Once it's been idling for a few mins at proper temp, cap it, and it should be fine.
My question: If i'm NOT losing coolant, as i'm not low, ever, BUT i am getting air into the system now and then, what could cause this?
-Gagan
Old Apr 6, 2003 | 08:46 PM
chrisw's Avatar
Car Info: 2003 blue EVO
check the radiator for signs of leaking. Silly subaru, they use plastic end caps.
I have already had my radiator replaced under warrentee because it started leaking.
Old Apr 7, 2003 | 09:33 AM
odyss3y's Avatar
Car Info: 2002 WRX
Gino's ( And Also Dave's Friend Jason's) Advice:
-Gagan
james
Old Apr 7, 2003 | 09:48 AM
You may have a small hole in the plastic part of the radiator or, if you have an overflow tank, in the coupling between the tank and the radiator or you shouldn't use cabonated water when filling the radiator
Old Apr 7, 2003 | 11:21 AM
BlingBlingBlue's Avatar
Sounds to me like you have some air in the system.
Old Apr 7, 2003 | 04:16 PM
joltdudeuc's Avatar
Old School
Originally posted by odyss3y
james
I was close! Noted, and Edited
-Gagan
Old Apr 7, 2003 | 04:36 PM
BlueGargantua's Avatar
Yeah
I went through that trapped air in the system mystery as well. When it started up it sounded like a small stream or a "whooshing" sound that only water and air can do. I burped the system and added water/coolant and problem went away
I dont have the stock radiator anymore, but there have been many a plastic stock radiators go bad so maybe you have a tiny leak.
Old Apr 7, 2003 | 04:37 PM
joltdudeuc's Avatar
Old School
Originally posted by BlueGargantua
Yeah
My thing is, i've looked for leaks, and find none....
:shrugs:
-Gagan
Old Apr 7, 2003 | 05:08 PM
scoobiesnacks's Avatar
:shrugs:
-Gagan
Most of the times a pressue test will help you find the leak.
