vf34 with stock intercooler
Old Aug 3, 2004 | 11:36 PM
anthonymx's Avatar
would a vf34 bolt up with a stock intercooler?, or would i need a fmic or different tmic
Old Aug 3, 2004 | 11:49 PM
Long_Travel_WRX's Avatar
Car Info: stock 04 wrx sedan
you will be fine mounts just like it was from the factory, and no you will not have to replace you stock IC only if you wish to upgrade like me
Old Aug 4, 2004 | 12:26 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Definitely works.
Old Aug 4, 2004 | 01:10 AM
AzN121184's Avatar
Car Info: civic
yes it'll work, i've seen people run vf30/vf34's with stock ic making about 270 whp
Old Aug 4, 2004 | 01:17 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Yes, it will be fine. You should upgrade your intercooler hoses while you are at it. Worth every penny.
Old Aug 4, 2004 | 01:18 PM
bassplayrr's Avatar
One more vote for no porblems. This is the set up Zoeb (02blackwrx) is currently running and I belive he puts out something in the 270whp range. SsTiNgEr77 even uses a VF22 with a stock intercooler with no problems.
-Chris
Old Aug 4, 2004 | 03:57 PM
Zoeb2s's Avatar
I <3 White Girls
Yup, like Chris said...stock intercooler on my VF34 setup with all the supporting mods....a larger TMIC would be good, but is definatly not needed.
Yes, definatly upgrade all hoses, including the turbo inlet hose...
Old Aug 6, 2004 | 12:19 AM
InfamousDX's Avatar
Hell you can even run a Green on stock top mount but it's obviously not gonna be as efficient and you can't run as much boost on bigger turbos + stock top mount.
Old Aug 6, 2004 | 09:56 PM
knight1833's Avatar
Car Info: 98/05 RSTi
02BlackWRX:
What are the necessary/minimum supporting mods for a VF34?
What else would you recommend?
thanks
KronikInsomniaK
Jul 21, 2012 03:07 PM
STi_Mark
May 12, 2007 09:25 AM
Antonio85
Jun 24, 2005 10:24 AM
WRX2ndregime
Subaru OEM Parts For Sale
Dec 17, 2004 11:40 PM
Slack
Aug 25, 2003 09:45 PM
