uppipe o2 sensor (removal)?
Old Sep 27, 2005 | 12:01 PM
Turbo86's Avatar
Car Info: 2003 WRX Sedan
Question uppipe o2 sensor?
im installing my uppipe on saturday and i need to get the o2 sensor unscrewed so i can remove the heatshield. i heard theres a special wrench or wrench head that is designed for the o2 sensor so it's easier to remove.
any idea were i could by something like that?
Old Sep 27, 2005 | 12:20 PM
drew935's Avatar
Car Info: 02 WRB Wagon
just use a 7/8" wrench. There's not enough room to use an o2sensor socket.
Old Sep 27, 2005 | 12:31 PM
AzN121184's Avatar
Car Info: civic
if you dont care for the heatshield, just dremel or use a cutter to cut it off.
Old Sep 27, 2005 | 12:34 PM
0 4 P S M W R X's Avatar
Car Info: a 2.5RS not an 04PSMWRX
i bought mine at autozone
Old Sep 27, 2005 | 12:42 PM
A 04 GUIZE's Avatar
Car Info: 06 EVO IX 67 COUPE DEVILLE
i didnt know there was an up pipe o2 sensor
Old Sep 27, 2005 | 01:11 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
there isnt . . . its located on the manifold, not the uppipe
Old Sep 27, 2005 | 01:18 PM
mbquarts's Avatar
Car Info: 03 MBP WRX
The best way is to cut the heat shield. I used a hack saw and wire cutters to cut out a notch in the heat shield so it would come off without removing the o2 sensor.
Old Sep 27, 2005 | 05:22 PM
Peaty's Avatar
There is if you get the right type of O2 sensor tool:
http://www.scoobymods.com/forums/showthread.php?t=5464
info and pics there
Old Sep 27, 2005 | 05:44 PM
mattsn0w's Avatar
its an EGT sensor on the up.
Old Sep 29, 2005 | 10:01 PM
bluewrx82's Avatar
matco 1/2 drive o2 socket works great, i lil pricey though
JASC
Nov 27, 2012 02:42 PM
WRBLUEballs
Sep 30, 2008 03:39 PM
DetailAddict
May 3, 2007 03:08 PM
lvfc_rook_1503
Jul 20, 2006 05:38 PM
Wildblitz1337
Feb 18, 2006 06:35 PM
