upping boost on '04
Old Nov 7, 2004 | 06:40 AM
whiting's Avatar
upping boost on '04
My friennds brother said that he is running his '04 WRX on 20 pounds of boost. I didn't think this would be possible without running into detonation. He has no upgrades to his fuel system. I mentioned that i wanted to up boost but also upgrade to STI injectors and walbro fuel pump. He said that the ECU wouldn't read the increased fuel delivery, but i figured it would, I am looking for an expert opinion. do i need a new brain if i upgrade fuel delivery and boost, i plan to run a AVR-C not just a mbc
Thanks for helping a NEWBIE
Old Nov 9, 2004 | 08:10 AM
BoostinEJ20's Avatar
stock wrx turbo can only hold up to 16 psi safely i believe...without upgraded fuel management etc its probably not very safe if it doesnt blow...
newbie too...just what i know so far...
anyoen corect me if im wrong
Old Nov 9, 2004 | 08:36 AM
SilverRex04's Avatar
Car Info: 04 Sti swap, VF22 18psi, 255l fule pump,ecutek 93 oct, Full exhaust TXS, Sti ra gears, much more...
I learned my lesson 04 rex with cai, bov and mbc running 17.5lbs of boost. It melted the probe on the egt sensor and now my car runs like crap, until i can fix the turbo. Tom
Old Nov 9, 2004 | 11:39 AM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
I run 16.5 in every gear all day long using an Apexi AVC-R ebc. The wrx can handle 18 psi. 20 psi is stupid with no other upgrades. Get ready to buy a new engine.
Old Nov 9, 2004 | 01:39 PM
RussB's Avatar
Car Info: $200,000 sports car
the only really safe way to increase boost on a wrx is a reflash as a minimum. even then, he probably won't see much over 16psi, and it definitely won't be for the entire rpm range.
the wrx engine can handle 20psi just fine, as long as it's from an upgraded turbo that isn't blowing extremely hot air, and has upgraded fuel injectors, exhaust, ecu, etc...
the stock ecu will not work properly with larger injectors, another reason reflashing or other engine management is necessary.
Old Nov 9, 2004 | 02:03 PM
mmboost's Avatar
that's not too bright.
Old Nov 9, 2004 | 06:40 PM
yeah i ran my car once up to 1.7 bar with the stock turbo i just re did a few lines and it was fast as could be. im not going to tell you how, youll blow your motor up. i only did two pulls but it was fun.
yzercyber
Aug 12, 2005 03:42 PM
Xarch20
13
Apr 27, 2004 12:03 AM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
