TurboXS Cast Iron Uppipe vs a Flex Uppipe
Old Nov 30, 2003 | 08:22 PM
huck's Avatar
Car Info: 2013 GR STi
Well, I was planning on going the TurboXS upgrade route but I was also planning on getting a Flex Uppipe (lets say Helix for the sake of argument) so I've hit a dilemma: TurboXS Cast Iron Uppipe or a Helix Flex Uppipe?
I've never heard any feedback regarding the TurboXS uppipe, has anyone else? What's everyone's input?
Old Nov 30, 2003 | 08:30 PM
iLoqin's Avatar
Car Info: Nadda
Flex is a lot better with long term use with out any problems if installed correctly. Flex again compensates for the expansion of heat, putting less force onto your flanges, therefore less if any leaks at all. But there are many on the boards that haven't had problems with non-flex uppipes.
I have not heard anything about the TurboXS Uppipe.
Old Nov 30, 2003 | 08:56 PM
huck's Avatar
From their site:
TurboXS Uppipes are manufactured to exacting standards from the same cast iron as the factory manifold, to maintain the same quality, expansion and fitment characteristics. By removing the restrictive factory catalytic converter uppipe, you will increase exhaust flow to the turbocharger, increase HP, reduce turbo lag, and eliminate the chances of a damaged catalytic converter destroying the turbocharger.
The thickness of the TXS Cast Iron Uppipe offers superior heat retention properties over a thinner stainless steel version, maintains more exhaust energy, increases turbo performance and reduces fatigue.
Why is the retention of heat so important? Heat is energy and since Subaru located the turbocharger so far from the exhaust ports, keeping heat in the exhaust is critical for turbocharger performance.
Why is the uppipe inner diameter critical? TurboXS uses an inner diameter of 45mm, which happens to be the inner diameter of your turbochargers exhaust inlet. This promotes the best possible performance throughout the entire RPM range by maintaining exhaust velocity. Over sizing the inner diameter of the uppipe slows exhaust velocity and creates turbulence as it enters the smaller inlet of the turbocharger, ultimately hurting turbocharger spool up. Exhaust velocity is critical!
Each uppipe is black anodized to for corrosion protection. Extra thick CNC machined flanges ensure proper exhaust gas sealing that has plagued so many other stainless steel uppipe designs. This uppipe will last the test of time!
Old Dec 1, 2003 | 02:29 AM
Daredevil's Avatar
stock has flex
Old Dec 2, 2003 | 10:45 AM
huck's Avatar
No one know anyone that has used the TurboXS uppipe?
Old Dec 2, 2003 | 02:38 PM
mmboost's Avatar
How can turboxs say that ("manufactured to exacting standards from the same cast iron as the factory manifold, to maintain the same quality, expansion and fitment characteristics") if its not a flex pipe?! Do they think the flex is not part of the "exacting standards"? Sounds like shift wording to me .
Get a flex pipe... and check the other recent thread on the same/similar topic
https://www.i-club.com/forums/showth...threadid=39935
jason
Old Dec 2, 2003 | 10:53 PM
huck's Avatar
Very good point, Jason. Thanks.
i-max
Hawaii Classifieds
Jun 25, 2011 07:40 AM
jagstyle
May 4, 2008 05:11 PM
iNfEk
Apr 5, 2005 01:25 PM
Daredevil
24
Sep 29, 2003 08:24 AM
spdkills
Feb 25, 2003 06:13 PM
