Uppipe question? TO flex or not to flex
Old Sep 24, 2003 | 05:24 PM
Daredevil's Avatar
yes, we all know flex is the way to go, but i need power for cheap $ what exactly does the flex help do, i've heard helps oil leaks, but then why do the majority of companies sell nonflex uppipes and people don't complain?
and who would you recommend for an uppipe?
thanks
max
Old Sep 24, 2003 | 05:58 PM
Flex uppipes are much easier to install. This makes them less prone to gasket leaks, as well as more easily able to soak up heat expansion without stressing the flange connections.
Old Sep 24, 2003 | 06:24 PM
BlkRx's Avatar
Car Info: 2004 Black Wrx
if you live in areas with cold winters you should get an uppipe with a flex joint. Metal expands and contracts in heat and cold and the flex joint will help compensate for this.
Old Sep 24, 2003 | 06:34 PM
BlkRx's Avatar
Old Sep 24, 2003 | 08:40 PM
DOHCammin's Avatar
Car Info: 05 CGM FXT STi
"power for cheap"
the helix up-pipe/downpipe combo is on sale at www.gruppe-s.com the up-pipe alone is pretty inexpensive and it has a flex joint.
Old Sep 25, 2003 | 01:23 AM
supra_man's Avatar
what if you live in a hot and humid climate? like hawaii what would you recomend?
Old Sep 25, 2003 | 12:18 PM
Group B's Avatar
Dahveed aka Robin Hood
wrong, the stocker is indeed a "flex" uppipe...
Originally posted by batmanalan
NEVER DO FLEX! ever.
the stock one doesnt have flex and does it work?
thank you,
and to all you people that post stuff they just hear and dont know, stop please.
Old Sep 25, 2003 | 12:50 PM
Daredevil's Avatar
well
i bought the helix uppipe and downpipe this morning, should be on my door step tomorrow (bought from gruppe s, i live real close)
anyone know the difficulty level of isntallnig these pieces?
Old Sep 25, 2003 | 01:30 PM
Daredevil's Avatar
jessu.. is it hard lifting an engine? i don't have a motor lift or nothing
and yea, i have a buddy of mine helping me
huck on the forums
Old Sep 25, 2003 | 01:50 PM
flex disrupts the turbulence.
stock most def. doesnt have a flex.
does vishnu, txs, godspeed have a flex? NO do they know what they are talking about, yes!
Stock indeed does have a flex joint, you just can't see it under the heat shield. Vishnu has both flex and non-flex joint uppipes. Non-flex pipes MUST be made of very high quality steel, have very thick flanges, and joint reinforcements as the Vishnu 321 pipe does. Flex pipes can get away with using a lower quality material, since is there is far less strain on the flanges from thermal expansion.
