Turbo Upgrade (downpipe) Questions
Car Info: Old Brighton
Turbo Upgrade Questions?????
I'm just wondering if you change to a bigger turbo do you have to change your downpipe to accomodate the new bigger turbo or will it align with the holes of the old downpipe...
The VF series IHI turbos have the same bolt pattern as the stock and aftermarket downpipes. You don't want to use the restrictive stock downpipe with a big turbo. What type of turbo upgrade are we talking about?
doh you beat me to it
Like what has been said above, it all really depends on which turbo you wish to upgrade to. Also, it is not good to run a stock downpipe with a turbo upgrade. After all, if you've got the money to do an upgrade and you want more power I assume, then why stick with stock DP?
I've got the invidia turboback on my car right now
I was just checking if i need to change the downpipe(again)to make the bigger turbo fit..Thanks for your replies
TenaciousEJ25
Nov 9, 2007 10:06 PM
Hurucan
Feb 27, 2006 04:30 PM
Pogi
24
May 21, 2004 09:09 PM
1Slow///M3
Sep 5, 2003 07:28 AM
