Torque on block drain plugs?
Old Apr 23, 2004 | 06:51 AM
wolfen42's Avatar
Question Torque on block drain plugs?
I'm going to be trying to COMPLETELY drain my engine of the stock coolant mix to switch over to NPG+.
Anyone know what the torque specs are for the drain plugs on the bottom of the engine? (The two 14mm hex keyed plugs)
Old Apr 23, 2004 | 08:07 AM
ish's Avatar
ish
those bolts get tightened to 50.6 ft-lbs
however when draining the coolant system, you don't need to access the "service hole plugs"
Old Apr 23, 2004 | 09:22 AM
wolfen42's Avatar
Post
Thanks for the info...
I figured that I would need to use those drains if I wanted to actually get almost every drop out of the whole system.
(I'm replacing my coolant with NPG+ which is NOT compatible with water...)
Old Apr 23, 2004 | 09:26 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
I thought about doing that...but the complete drain sounded like a pain. Doesn't the water rise to the top and you can just suck it off?
MikeyT
Dec 7, 2011 04:12 PM
Speed Element
Jun 30, 2008 03:31 PM
Speed Element
May 28, 2008 03:04 PM
newtosubaru
Jan 9, 2004 04:08 PM
