Timing belt 2002 wrx
Old Jan 12, 2013 | 11:13 AM
02wrxguy's Avatar
So my car is still misfiring on cylinders 1 and 3. I've ruled out spark plugs at this point and swapped the coil off 2 and no change . Also fuel is getting to the cylinders as both plugs have gas on them. I'm leaning towards an ignition problem with the timing or spark. The motor I have the ej20 is a coil on plug. My question is , is there a distributer for the plug wires and if so where is it located in the bay? Secondly assuming its not a spark issue from a bad distributer and it's ignition timing would a skipped tooth cause a misfire on only two cylinders? Please if you have any info anyone please let me know as Im stumped at this. Point . Thank you in advance
Old Jan 12, 2013 | 11:19 AM
Superusdm's Avatar
Car Info: 2003 WRX
It's worth looking at considering how easy it is to check. Has the timing belt been replaced? Mine was pretty strecthed (and potentially causing my misfires) at 92k.
Old Jan 12, 2013 | 11:21 PM
02wrxguy's Avatar
It was supposed to be changed by the mechanic back in July however im having doubts that they actually did the work they said
wagonrasa
Jun 1, 2012 01:23 PM
solbergwannabe
13
Sep 2, 2005 09:08 PM
190hpkilla
Feb 21, 2004 04:40 PM
