2002 WRX Timing belt raplcement
Old Aug 6, 2005 | 07:54 AM
solbergwannabe's Avatar
I am thinking about purchasing an '02 WRX. Due to the amount of miles it is going to need a timing belt and waterpump replacement. Now I am a decent mechanic without a proper lift, is this something a person with a service manual can do without access to a lift? I have performed similar work on other cars, but not on boxer engines.
Also since I have never owned a boxer engine/ subaru, how does one go about getting to the spark plugs? is it easier than it looks? Becuase when I look at pictures of a wrx engine bay, I cannot even see them down there.
All information will be greatly appreciated.
Old Aug 7, 2005 | 10:49 AM
timing belt
sundaymorningbump
nobody knows?
Old Aug 7, 2005 | 04:03 PM
tekfoc's Avatar
Car Info: URBAN GREY 07 STI
your best bet is to get someone to help you who has worked on subarus before , its very easy too screw up these engines if you never worked on them before. good luck
Old Aug 7, 2005 | 11:24 PM
FiDRcr's Avatar
You should call around different shops...if you are in the bay area, there are some shops like LIC and Gruppe-S that could give you a better answer.
~luke
Old Aug 8, 2005 | 06:36 AM
Egan's Avatar
I would highly recommend that you pay someone to do the timing belt. It is a major PITA and you need the proper press to get the pin back into the tensioner. Don't get me wrong, the home mechanic can do it, but with the tensioner and the dual overhead cams, and trying to get everything lined up correctly, it's not easy.
Old Aug 9, 2005 | 11:39 AM
thanks
hey thanks guys for the info... subaru said about 430 for the timing belt, drive belts , and crank seal. I didn't think that was a bad price at all.
THat doesn't include the waterpump. Would you recommend having the water pump replaced too.. bumps up the price to about 640. The guy at subaru says he hardly ever replaces the water pumps. The wrx i am looking at has about 110,00 miles on it and is a 2002.
What do you guys think about the water pump being replace, is there any need?
The car doesn't have any cooling problems and is completely stock.
Old Aug 9, 2005 | 01:07 PM
tekfoc's Avatar
you should replace the waterpump for piece of mind , cause if it starts going bad you could easly loose your motor . coolant will start leaking all over your new timing belt causing it to snap and their goes your motor. I went threw this a couple years back on my old ford escort said to my self aaaa dont need the waterpump just the belt 6months later water pump started leaking on the new belt causing it to snap. got lucky cause that motor is non interfearence motor but are suby motors are not !! . good luck
Old Aug 11, 2005 | 06:51 AM
ride5000's Avatar
are you saying that coolant dissolved timing belts?
Old Aug 11, 2005 | 12:54 PM
tekfoc's Avatar
causes it to stretch enough to jump out of timing or snap.
Old Aug 11, 2005 | 12:59 PM
ride5000's Avatar
coolant??
propylene glycol, causing a timing belt to stretch and/or snap?
i've never heard of such a thing. i think you had other issues that caused your previous belt failure.
people spill antifreeze all over their belts (timing/accessory/etc) all the time.
Old Aug 11, 2005 | 01:14 PM
tekfoc's Avatar
Originally Posted by ride5000
coolant??
you could be right but why take the chance since the belt is off and he is doing the front main oil seal also and the mechanic is looking right at the waterpump while he is doing the work might as well change the waterpump.. he stated the rex has over 100.000 miles. why spend money twice for labor to change out the waterpump later. remember he just got the rex and doesnt know all the history of usage.
Old Aug 14, 2005 | 01:16 AM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
At what mileage should you have the timing belt replaced anyway??
Old Aug 14, 2005 | 03:01 PM
SoCalROB's Avatar
Car Info: 2006 CGM WRX Wagon
I beleive I read at 105,000.
Old Sep 2, 2005 | 09:08 PM
fastnoypi's Avatar
sparkplugs are easy..pull out the washer tank to get more room on the drivers side
use a 1/4" ratchet and socket to pull the coil packs off
use a sparkplug socket and 3" extension to pull out the plugs with a 3/8 ratchet
dont bother with a swivel and long extensions
02wrxguy
Jan 12, 2013 11:21 PM
wagonrasa
Jun 1, 2012 01:23 PM
190hpkilla
Feb 21, 2004 04:40 PM
