technical rebuild ??
Old Dec 2, 2005 | 01:49 AM
GiliganWRX's Avatar
Car Info: 2007 STI
Question technical rebuild ??
ok i blew my ej20 and i am rebuilding. new rods pistons ect. now my quiestion will a usdm sti crank work in order to get a longer stroke? if it will will it raise compression. the pistons i ordered are ross racing pistons with a 92mm bore witch is stock i believe. and those pistons are 8.5:1 compression. so will the sti crank raise the compression too high because i am planning on a gt35 in feb/mar time frame?
thanks for input
Gil
Old Dec 2, 2005 | 02:01 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
No the USDM (EJ25T) crank will not work in the (EJ20T) block. Talk to Crawford or AxisPower about building a motor, they will be able to help get you something good setup in your car.
Good luck,
Austin
GotBoost?
Dec 30, 2003 12:14 PM
RedBaaron
Nov 13, 2003 03:49 AM
wrxevo5
Aug 4, 2003 08:25 PM
stealth-wrx
Mar 10, 2003 01:07 PM
Red Rocket
Nov 22, 2002 11:55 AM
