Stock Turbo Failure
Old Sep 24, 2004 | 07:32 PM
Mister 2's Avatar
did you just get the car back from the shop? check your ic hoses and the vacuum line going to the bypass/BOV.
Old Sep 24, 2004 | 07:43 PM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
Its entirely possible that you have another bad turbo?... make sure that the oil cooling line is attached to the turbo.... also its highly possible that they may have not precharged the turbo.... also make sure your not hearing any obvious leaks... especially from the up pipe.
I would take it back to the dealer and park it in front of the service gate.... they are responsible for servicing your car especially as it relates to warrenty work. If they didnt do the job correctly and its costing you in other area's then you are the priority ... amke them know it!!!.
-K
Old Sep 25, 2004 | 11:44 AM
itwrx's Avatar
Car Info: 03 WRX Blue
What about a piece of the cat in your uppipe messing the turbo up?
Old Sep 25, 2004 | 01:16 PM
Kwilson21's Avatar
Sounds like you may have gotten a refurb/rebiuld turbo which isn't uncommon. I would put serious pressure on them. Tell them that anything wrong with the car..i.e. the intake latch was fine when you brought it in. Tell them that everyone is busy and that if the job was done properly in the fist place then they would be even less busier due to the fact that you wouldnt be there bothering them.
I would also investigate the possabilities of using another more competant dealer since the one your using seems to be obviouly lacking in any technical ability and or any diagnostic skills. As per the loaner i would think since this is warrenty work that yes they should give you something however dont expect them to offer it.... usually its first come first serve. I would call and insist that if the time estimate as they state it is then you should most certainly at the top of the list. If they give you any hard time get the names of the service department manager and speak to the dealer manager or owner and insist that this be a priorty or you will be calling a lawyer and most certainly SOA corporate office.
Get pissed already... you payed for it....
-K
Papatel
Jul 10, 2009 04:03 PM
polishwrex
Sep 8, 2008 09:57 PM
suba-rulez
Feb 1, 2007 02:27 AM
code3scooby
Nov 7, 2006 01:49 AM
Mr. Rogers
Jan 4, 2003 09:28 AM
