stage 2 crank hp
Old Sep 10, 2006 | 11:29 AM
TurnWRX's Avatar
stage 2 crank hp
I recently got dynoed on a mustang dyno and churned out 200 whp. What does that equate to in terms of crank hp?
Old Sep 10, 2006 | 10:31 PM
Subie do's Avatar
Cobb rated the WRX M/T at 285hp.
http://cobbtuning.com/wrx/power-s.html#Stage2
Old Sep 11, 2006 | 02:38 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Cobb claims 285 HP at the flywheel (224 at the wheels on a Mustang dyno) so I would guess that would put you somewhere around 260 at the flywheel. What supporting mods are you running, what octane fuel were you running, what was the outside temp and did you have the car dynoed right after an ecu reset?
Just curious since you saw such a low # and since I'm at Cobb stage 2 also.
BTW, what year WRX do you own?
Old Sep 11, 2006 | 07:15 PM
TurnWRX's Avatar
91 octane California Costco gasoline
03 wrx, just your basic stage 2
temp was like 85-90 degrees at time of dyno
Old Sep 12, 2006 | 06:32 PM
WRX409's Avatar
Car Info: 04 WRX
Those numbers are just about right.
Cobb does rate it at the flywheel.
KTW
Jul 12, 2004 07:33 PM
casualsurfer
May 3, 2004 03:24 PM
Cend_wrx
Apr 5, 2003 12:03 AM
mattr762
Mar 26, 2003 11:47 AM
pillaka
29
Dec 1, 2002 01:14 PM
