Uppipe Suggestions - 2002 WRX
Old Sep 11, 2006 | 06:08 PM
dhm2163's Avatar
Car Info: 2002 WRX
Looking to replace OE with an AM unit and looking for suggestions from those that have done this successfully.
My main concern is whether or not to obtain an AM pc. with the flex coupling (is this necessary as the original engineers designed it that way).
Also not wanting to spend much more than $200.
Thanks for comments, please keep it short.
Old Sep 11, 2006 | 06:16 PM
testes1010's Avatar
They(subaru engineers) also put a cat in it. A properly designed uppipe will not need a flex section, it is a crutch for poor design/tolerances.
I vote Crucial Uppipe. A bit over $200 but well worth it IMHO.
Old Sep 11, 2006 | 06:27 PM
dhm2163's Avatar
Car Info: 2002 WRX
...and an exhaust gas temp sensor, yes.
Is your comment regarding poor design tolerances justifiable somehow (where did this notion come from?)...what about heat/vibration/creep/etc. Some AM pcs. have the flex.
Thanks for the advice.
Old Sep 11, 2006 | 06:33 PM
testes1010's Avatar
IMHO, there is no need for a flex section on a properly designed/engineered uppipe.
I'm sure it was much cheaper for subaru to incorperate a flex section than to actually require tighter tolerances that could slow down production as well as cost more to produce to spec. Same with aftermarket.
the factory egt is for cat temperature, not actual EGT.
Old Sep 11, 2006 | 06:43 PM
dhm2163's Avatar
Car Info: 2002 WRX
Maybe inferred cat bed temperature, but it was my understanding the sensor was installed in the pipe.
Regardless, how long have you had your pc. installed?
Old Sep 11, 2006 | 07:39 PM
subie OCD's Avatar
Car Info: 04 STi
Crucial racing looks like a nice one, Helix is a popular brand.
I have a gutted oem uppipe.
Old Sep 11, 2006 | 08:29 PM
TurnWRX's Avatar
hks uppipe
Old Sep 11, 2006 | 08:35 PM
wrex 2.0's Avatar
Car Info: 03 wrx
helix and aps are nice up pipes, you will probably have to trick the sensor in the up pipe otherwise you could get a cel.
Old Sep 12, 2006 | 03:34 AM
testes1010's Avatar
I've ran the Crucial pipe for almost 3 yrs.
Old Sep 12, 2006 | 04:03 AM
Jakes02's Avatar
Car Info: 2002 WRX
cobb tuning. http://cobbtuning.com/wrx/power-i.html#uppipe
http://cobbtuning.com/wrx/pr-uppipe.html
Old Sep 12, 2006 | 02:34 PM
MO REX's Avatar
Car Info: 02 PSM WRX
+1
I don't have one but I do know that unlike Helix the Crucial pipe ID matches the turbo inlet, it's coated inside and out, and it has a limited lifetime warranty.
I used some Subaru bucks and bought a STI uppipe since it was basically free. I'm happy with it but if the money would have been coming out of my pocket I would have bought the Crucial. I'm not saying I know that it's the best uppipe for a WRX but I can say without a doubt that it is a very nice pipe.
If you plan on upgrading to a big turbo with a bigger inlet in the future you might be better off with a Helix or some other pipe that has a bigger ID.
BTW, Cobbs Inconel 625 uppipe looks very nice also but $375.
Old Sep 12, 2006 | 06:37 PM
WRX409's Avatar
Car Info: 04 WRX
I would go with the Cobb uppipe but, that's just me.
Good luck with whatever you go with.
steen80
Dec 27, 2013 06:45 PM
Juicewuh
Jun 8, 2013 09:05 AM
prspect06
Feb 25, 2005 06:40 PM
V8haha
Jun 26, 2003 12:53 PM
Zoeb2s
Jan 19, 2003 06:11 PM
