slow car & boost problems
Old Jul 9, 2007 | 08:36 PM
AspenWhite04's Avatar
Car Info: 2004 WRX
So I have 2 problems Im lookin for help with 1) I've spent a little over $3k in new tires, QTP downpipe, Cobb AP stage 2 and some others im still waiting on. On stock parts I was running 15.1 @ 89mph. After these mods Im running 15.2-15.5 @ 94mph. Im running the same 60' & 60mph faster in the 1/8th?? The more I dump in the slower it goes???? and 2) goin down the hwy in 4th or 5th gear at 3k rpm and then just slam the gas down I boost up to 16 psi then down to about 11 and back and forth till i let off. It only does it in these two gears everything else just sticks at 14-15 psi?? Am I in need of a tune?
Old Jul 12, 2007 | 02:09 AM
bluekn8286's Avatar
Smile
you typically do not reach maximum boost until about 4th or 5th gear (you will not be boosting to 16 psi in every gear). As far as the slower times, I would try and get a tune; some cars do not take well to the Cobb base maps, but others do. In any case, if there really is a problem then your tuner will most likely be able to tell you.
Old Jul 12, 2007 | 09:29 AM
+1 i think its the AP after i tuned my car the boost fluxuation went away
Old Jul 12, 2007 | 09:35 AM
VRT Gump's Avatar
you should always tune your car shelf maps are ok at best.
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
roflrofl
Oct 7, 2005 01:18 AM
Mach5WRX
Apr 3, 2004 01:52 PM
Forced Impreza
Oct 14, 2003 10:38 PM
