VF39 turbo with modded injectors Q?
Old Jun 13, 2007 | 04:25 PM
JDMWrx04's Avatar
Car Info: subaru wrx 2004
I am planning to do a swap from the stock wrx turbo to a vf39 turbo on my 04 wrx and i was wondering what injectors would be good with the turbo just about maxed out. I heard about the "modded injectors" that flow about 740cc. Is it possible i can run those modded injectors without having too much fuel? And also where are the injectors located at??? Any help would be appreciated
Old Jun 14, 2007 | 10:37 PM
1sicwrx's Avatar
You can run the STi Pink injectors. Plenty of WRX's have them with all the bolt ons and they don't max out. The STi in Japan with the 2.0l motor runs these same injectors so they are specifically manufactured to run on the 2.0. The injectors are located pretty much right on top of the cylinder head(technically the side of the heads but you get the picture). Oh yeah, if you don't get those, make sure to get "Top feed injectors" because the 2.5 motor runs side feed injectors.
Old Jul 8, 2007 | 04:02 PM
WRX409's Avatar
Car Info: 04 WRX
The STI pink fuel injectors will work fine and you
shouldn't max out the injector cycle duty.
Old Jul 12, 2007 | 01:45 PM
JDMWrx04's Avatar
ok. looks like ill be getting the pink injectors. Thanks for the info
cwc16
Sep 7, 2012 12:00 PM
nkghost
Misc Items For Sale
Sep 10, 2008 02:44 AM
kyoung05
Aug 1, 2007 08:18 AM
flipmode
Nov 4, 2006 08:37 AM
